Project14
Project14
Documents Project14 | You Decide the Next Monthly Project Competition!
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Date Created: 10 May 2017 8:26 PM Date Created
  • Last Updated Last Updated: 23 Sep 2024 3:52 PM
  • Views 61604 views
  • Likes 20 likes
  • Comments 338 comments
In the Forums or as an Idea:  Send Your Suggestions for Future Themes and vote on them!
 Forum  / Theme Suggestions
How are Themes selected?
 Project14 | Quick Update on Upcoming Competitions + What Would You Like To See Happen In Project14?
  • led display
  • communication_protocol
  • music tech
  • home automation
  • decide the next monthly project competition!
  • monthly_project
  • project14 featured
  • arduino home automation
  • analog devices
  • analog & digital wireless communication
  • project14
  • test & measurement
  • arduino communication
  • analog on pi
    dougw over 9 years ago +24
    I guess the suggestion box moved here so I will reiterate one idea I mentioned earlier and add one: - a classroom demonstration of some physics phenomenon ( jc2048 had some good ideas ) - a solar powered…
  • jack.chaney56
    jack.chaney56 over 9 years ago +11
    Keeping with July and (northern hemisphere) Summer time, I like Douglas' ideas. Demonstration of physical phenomenon for classroom is a great avenue, I was thinking lots of solar stuff. Charging systems…
    balearicdynamics over 9 years ago in reply to Workshopshed +11
    I will ad also a time machine. Sound good ? Enrico
  • ninjatrent
    ninjatrent over 9 years ago
    The Tin Man Heart is one of my photos. image I put a Raspbery Pi Zero and Adafruit PiTFT 320x240 2.2" TFT Display HAT in an Altoids tin.
    Here is another one that I made with a different cable config.
  • ninjatrent
    ninjatrent over 9 years ago in reply to ninjatrent
    It would be interesting to see if someone else could make a better version of a RetroPie gaming console in an Altoids tin. While the Adafruit display fit inside of the Altoids tin, the buttons that are located under the display are not necessary. One limitation of my original design was that the audio was provided by a USB speaker. It was my intention to put a small speaker inside the Altoids tin but I ran into some issues with creating an audio output for the speaker.
    dougw over 9 years ago in reply to ninjatrent
    I've seen mini USB speakers that would fit in a (second) Altoids tin.
    Or I have purchased replacement cell phone speakers which are much smaller - two could be run from one of those class D amps that is less than a square inch and 3.4 mm high.
  • ninjatrent
    ninjatrent over 9 years ago in reply to dougw
    Thank you for the suggestion. I just found an I2S 3W Class D Amplifier Breakout at Adafruit that will work. It has a built in DAC and will fit in the tin with a small speaker.  https://learn.adafruit.com/adafruit-max98357-i2s-class-d-mono-amp/overview
    There is another method of getting audio from the GPIO. https://learn.adafruit.com/adding-basic-audio-ouput-to-raspberry-pi-zero
    I might try the I2S Class D amp and a small speaker. If I do make a second version I might also use a small NTSC/PAL TFT Display wired to the video pins on the Pi Zero instead of the Adafruit PiTFT I used before. Thank you again for the suggestion. The Class D Amp, I2S DAC, and small speaker would be a great solution.
  • Workshopshed
    Workshopshed over 9 years ago in reply to ninjatrent
    Just about to add a I2S Amp to a Pi Zero too
  • ripntime
    ripntime over 8 years ago in reply to ninjatrent
    Got this little st of Sony speakers that came from a Sony walkman phone.  Nice little set run off a headphone but a small mp would make them so much better. Sound quality is incredibly good for their size. image
