Essentials
  • Essentials
Essentials
Forum Ohms law
Join Essentials to participate - click to join for free!
  • Replies 27 replies
  • Subscribers 1044 subscribers
  • Views 7601 views
  • ohms law
Ohms law
salesm21
salesm21 over 8 years ago
To anyone who can help,
I have been recently wondering about something rather simple. Why is it in ohms law does R=V/I & I=V/R? This means that voltage is proportional to both resistance and current? I know the more voltage you have the more energy is given to each coloumb of charge but why is it that when 1 volt of energy is in 1 C of charge is there 1 ohm?
    jw0752 over 8 years ago +8
    Hi Mitchell, Let's imagine that we have a perfect source of 10 volts with no internal resistance. What ohms law does is give us a formula for calculating the current in a circuit if we know the resistance…
    jw0752 over 8 years ago in reply to gdstew +8
    Hi Gary, While I tend to agree with you, if one really has a scientific thought process we have to leave open the possibilities. The scientific community went 200 years believing that they had things all…
    mcb1 over 8 years ago in reply to michaelkellett +8
    michaelkellett I'm with you. I've managed all these years without worrying about the unseen things causing it to happen. Quite frankly I don't really care which way they actually move, as long as something…
  • rsc
    rsc over 8 years ago
    Hi Mitchell,
    Keep in mind that Ohm's Law and most other equations are used for simulation only and physical things are not always that simple.
    If you put 10,000 volts across a 1 ohm resistor, you won't get 10,000 amps, you'll get a melted resistor.
    Resistance will change due to environmental factors also, a hot resistor or motor windings, or... will have a different value than when it's cold.
    Capacitance is also a moving target.  Humidity will change a capacitor's value.  Inductance is its own beast, and will change value just by being close to another part/wire/magnet/etc.  Equations are for estimating and simulating things, and are rarely correct for all circumstances.
    Clear as mud??
    (If you don't believe me, try measuring the resistance of mud)
    Scott
  • gdstew
    gdstew over 8 years ago in reply to rsc
    And contrary to other peoples opinion, that's why having at least a basic understanding of the fundamentals is important.
  • gdstew
    gdstew over 8 years ago in reply to michaelkellett
    Sorry, I don't buy into the lack of basic knowledge of electronics is good thing meme. It leads to making simple mistakes
    that leave the mistake maker with no clue as to why it doesn't work or how to fix it.
  • gdstew
    gdstew over 8 years ago in reply to DAB
    Based on the overall success of modern electronics from over a hundred years of research by some of the greatest minds in science
    and engineering I'll stick with everybody else is right and you are wrong. Thanks anyway.
    Hi Gary,
    While I tend to agree with you, if one really has a scientific thought process we have to leave open the possibilities. The scientific community went 200 years believing that they had things all figured out until Einstein showed them that at high speeds and high gravities the universe is not quite as simple as Newton portrayed it. I have looked briefly at DAB  's theories and I even bought his first book. If there is merit to his new ideas, at least, at the level that I do physics it is not worth changing from my familiar view. I believe that he might have better luck explaining things if the terminology did not overlap so much between his theory and the standard model. In the end I have chosen to stay with the standard theory of physics and not try to make the transition to something new. However, at this point, I would hesitate to tell DAB that he was wrong. We have even seen instances where two seemingly competing theories turned out to simply be the same but viewed from different mathematical perspectives. The test will be when DAB can propose an experiment whose result is correctly predicted by his approach and isn't correctly predicted by the current approach. I will keep my mind open but in the meantime, for me, electricity will remain the drifting of electrons through a conductor.
    • Vote Up +8 Vote Down
    DAB over 8 years ago in reply to gdstew
    That is fine.
    I am challenging everything everyone thinks they know about subatomic physics.
    I fully understand that nearly everyone will reject my ideas and findings.
    That said, the math proofs and data analysis of my theory versus conventional thought has clearly shown that I just might be right.
    My wife added a warning to the book for all students to not read the book until they are out of school and ready for independent thought.
    All I ask is for everyone to have an open mind and ask themselves honestly, just how well do you really understand what goes on when charge flows.  So far, I find many people really just accept the conventions, even when they defy logical conclusions.
    Case in point, Werner Heisenberg claimed that you cannot measure the positon of an electron around an atom because you cannot know its position at the time of measurement.
    Yet, if you take his data, he confirms the location of small mass/charge objects at roughly 10-34 meters, which is approximately the size of captured photons in my model.
    My model also validated he measurements by Niels Bohr when he found that all atoms appeared to have a diameter of about .5 * 10-10 meters, which is exactly where we found the balance point of the photon shell around the atomic nucleus for all atoms.
    So my work continues, but stacked up against accepted theory, I am beating the pants off all of the basic atomic assumptions.
    I use element14 as a sounding board to see if I can entice knowledgeable people to interact with.
    michaelkellett over 8 years ago in reply to gdstew
    Please, please don't put words into my mouth.
    And if you have circuit design example, of the kind that the OP is reasonably likely to encounter, where the actual speed or direction of motion of electrons (or, with due respect to DAB, if they actually move at all) in a wire matters, please cite it.
    To use an analogy, I know how the engine my truck works. When I'm driving it I don't think about injectors and pistons, I think about the torque demand pedal. I could run a perfectly good delivery service without knowing anything about how engines work. In the same way I can design perfectly good active RC filters without thinking about a single electron.This doesn't imply that it is good or bad to know or not know about electrons or engines - just that it doesn't always help.
    To quote Einstein: "Everything should be as simple as it can be, but not simpler", the appropriate level of simplicity obviously depends on the context and the application.
    • Vote Up +5 Vote Down
    DAB over 8 years ago in reply to jw0752
    Hi John,
    In my latest update, I do propose a simple experiment to demonstrate my point.
    Take a glass tube with two electrodes on each end and fill the tube with only Hydrogen gas.
    Then apply voltage across the tube.
    What you will find is a stream of photons moving between the two electrodes. If you measure the current at each end of the tube, you will find a loss of charge running through the tube as the photons are emitted.
    If you use the electron model, then you should see each Hydrogen atom dissociate as an electron is ripped from its orbit, leaving a pile of protons at the bottom of the tube and little or no Hydrogen gas remaining inside the tube after a short period of operation.
    So how sure can you be that electrons are flowing instead of photons?
    A spectrometer shows a very wide range of photons being released between the two electrodes and a simple pressure check will show that no Hydrogen gas was lost during operation.
    Since photons are released every time you draw an electrical arc, why is photon flow such a difficult idea?
    Has anyone actually seen an electron flow through a wire?
    Just saying.
    jw0752 over 8 years ago in reply to DAB
    Hi DAB,
    When the difference in potential is put across your tube of hydrogen,  electrons are accelerated  and their increased velocities are the means by which energy is transferred to the hydrogen atoms. When there is electron - electron interaction energy is transferred to orbital electrons. These orbital electrons then emit a photon as they jump back to a lower energy level in the atom. There are cases where an electron is removed but it is quickly replaced with another and again photons of specific energies are released as it falls back into lower energy states.
    I do not understand why you say that I will find a stream of photons moving between the potential difference. Photons would be undetectable and they have no reason to move as they are not affected by an electric field. I might see a source of photons between the two potential terminals but these are successfully explained by the interaction of electrons with orbital electrons and their subsequent returning to lower energy levels.
    There is no need for the atoms to disassociate. Electrons are being supplied and recovered by the potential difference and the net ionization of the hydrogen gas will likely remain fairly stable. I am not sure what the characteristics are of the protons in your physics but from the standard theory they are positively charged which would cause them to repel one another. They would not accumulate at the bottom of the tube. Gasses that have a lot of ions are called a plasma and exist at very high temperatures such as your arc, in areas where the particle density is too low for easy recombination like the upper atmosphere or in places like the Sun's atmosphere where there is heat and low density. Even in plasma there is likely a net neutrality of charge.
    Using an ideal gas model you may be able to calculate the amount of hydrogen in the tube by measuring temperature and pressure. I would not expect this to change under the standard model up until the point where temperature became great enough for the gas to transition to a plasma. Frankly I do not know if the ideal gas law applies to plasma.
    If photons were affected by an electric field as you seem to indicate I should be able to place an electric field between my eyes and a light source and modulate the flow of the photons. This would produce a distortion that is not observed in experiments.
    Your ideas are interesting and always spark a discussion. Nothing that I do or experiment with has any need to have a precise theory at the molecular level. I like
    michaelkellett 's previous post as it accurately reflects how I feel. In the mean time when I feel like trying to imagine the atomic world I am comfortable with the standard theory even though I suspect that future revelations will tweak it towards more perfection without the radical change that you propose.
    Without sidetracking into the science (it hurts my head), the formula allows you to calculate the missing item when you know the other two.
    At some point someone worked out the maths and they all aligned.
    I tend to like the water theories.
    If you have a river that falls a long way that is the voltage (V)
    The river could flow a lot of water or there is very little to slow it down/hinder the flow (R)
    The amount of water flowing depends on both the amount of fall (V) and the resistance/hinderance (R)
    It not possible to have lots of flow when the resistance is high, or indeed when the fall is small
    Energy is a different equation or relationship, like the equations for work, etc.
