Essentials
  • Essentials
Essentials
Documents Related Components for element14 Essentials: Automation I
  • Author Author: pchan
  • Date Created: 23 Jan 2019 8:45 PM Date Created
  • Last Updated Last Updated: 18 Nov 2022 5:44 PM
  • Views 1176 views
element14 Learning Center
Automation I:  Control Panel Design
Sponsored byimage
The element14 ESSENTIALS of Control Panel Design covers the fundamentals and guidelines for designing an industrial control panel. This supplementary guide discusses the types of related components used.
Go to Learning Module
Control Panel Components
Type DRD DIN Rail Wiring Duct
Buy NowBuy Now
DIN rail wiring duct used for component mounting, provides design flexibility and component access for easier installation and maintenance.
image DIN rail is compatible with standard 15mm or 35 mm rails
image Integrated DIN rail fastening provides 40% faster rail and duct installation
image Hinged cover attachment ensures panel integrity during maintenance and upgrades
image Channel pass-through slots provide ease of wiring
image Reduces wire length, material cost, and labor cost
Corner Wiring Duct
Buy NowBuy Now
Corner Wiring Duct utilizes the unused corner space in the enclosure or duct and reduces overall footprint up to 20%.
image Reduces assembly cost using optional quick mount clips
image Compatible with Panduit 3" and 4" wiring duct
image Cover and Base length is 6 feet and sold separately
image The one-piece base needs less installation time than a multi-piece solution
Cable Tie, Pan TyRegistered Weather Resistant, Nylon 6.6 (Polyamide 6.6), Black, 99 mm, 2.5 mm, 22 mm, 18 lb
Buy NowBuy Now
A Locking Cable Tie is a type of fastener used for holding items together, primarily wires or cables. These versatile, weather-resistance ties are suitable for many indoor and outdoor applications.
image UV and weather resistant black nylon has no sharp edges
image Operating temperature range is -65°C to 85°C
image Faster threading and curved tip increases installation speed
image Requires low thread force
image High loop tensile strength
image One-piece locking section provides strength and reliability.
Wire Marker, Self-Laminating, 25.4mm x 19.1mm, Vinyl, White
Buy NowBuy Now
Laminating Labels are used for product identification to provide details about the product or cable.  Self-laminating labels supplied on rolls contain the print-on colored area and clear overlaminate to safeguard the legend for permanent and clear identification.
image Create professional labels with superior legibility
image Available in a variety of materials and wire sizes
TDP43METDP43ME Thermal Transfer Desktop Label Printer (UK), 300 dpi
Buy NowBuy Now
The Thermal Transfer Desktop Label 3dpi printer provides printed labels for component identification, with simple setup and smooth operation.
image Compact size and Durable construction
image Excellent resolution for small characters
image Automatic self-test and one button operation
image Allows sharing using network connection capability
image Reduces printer downtime using easy ribbon loading
image Supports all Panduit thermal transfer label media using Easy-Mark labeling software.
image Easily and quickly connects to PC and offers flexibility to print using Ethernet or USB
image Works in industrial and harsh environments.
Grounding Bar, #14 - #4AWG & 2/0AWG WIRE
Buy NowBuy Now
The Universal Ground Bar System (UGB) offers multiple mounting options and terminating methods. The UGB system helps to reduce the types of ground bars that are required to satisfy the various customer requirements.
image The UGB is CSA 22.2 Certified and UL 467 listed for bonding and grounding equipment up to 2/0 AWG
image Fulfills UL 508A requirements
Uninterruptible Power Supply (UPS), 28 V, 24 V, DIN Rail
Buy NowBuy Now
The Industrial Network UPS offers uninterrupted power and reduces the risk of downtime. Instead of batteries, it uses ultracapacitors, which eliminate downtime due to battery failure and provides maintenance-free design.
image Low cost as compared to a battery-based UPS
image Standard web browser interface decreases operation expense
image Ethernet connectivity for Remote management
image Temperature range is -40°C to +60°C
image DIN rail mount
image UL listed and CSA certified
Connector Accessory, RJ45 Jack Blockout Device, RJ45 Jack
Buy NowBuy Now
The RJ45 Jack Blockout Device prevents an RJ45 Jack from unauthorized access and harmful foreign objects, saving money and time related to data security, repair, hardware replacement, and network downtime.
image Compatible with a variety of RJ45 jacks
image Does not interface with jack contacts
image Requires special tool for installation and removal
image Ensures network infrastructure safety and security
Terminal, Wire Ferrule, DIN end, Single Wire, 24 AWG, Turquoise
Buy NowBuy Now
The DIN end sleeve single wire insulated ferrule has a funnel entry that provides lower installation cost and faster insertion. These ferrules are 12.5 mm long and have a wire strip length of 11.9mm.
image Meets DIN standards for single wire containment
image Provides easy wire insertion into the terminal block
image Variety of pin lengths are available for multiple terminal blocks
image Suitable for limited panel space applications
image Polypropylene insulation fulfills DIN color requirement
image Provides reliability and speed for high volume terminations
Ergonomic Cable Tie Tool, Hand Operated, Tension Control/Tie Cut Off
Buy NowBuy Now
The Cable Tie Installation Tool provides higher productivity and promotes worker safety. These hand-operated tools are suitable for low to medium volume applications.
image Cushioned slip-proof grip
image Lightweight (294.5 g)
image Slanting tie entry permits quick side entry of tie into a tool to provide fast installation
image Low handle force required to cut off the tie
image Adjustable control
image Easy to read tension settings
*Trademark. Panduit is a trademark of Panduit Corp. Other logos, product and/or company names may be trademarks of their respective owners.
  • control_panel_design
  • automation i
  • clem57
    clem57 over 7 years ago
    Nice
  • clem57
    Nice
