CodeBug
  • CodeBug
CodeBug
Forum do we need to buy a battery for codebug to work
Join CodeBug to participate - click to join for free!
  • Subscribers 13 subscribers
  • Views 1771 views
pls let me know
  • notdodgy
    notdodgy over 11 years ago +1
    I have used it with a battery and have heeded the warnings about removing it. Removing the battery needs some kind of insulated tool* to push it out as it is a tight fit to both insert and remove. Lollipop…
    balearicdynamics over 11 years ago in reply to notdodgy +1
    CodeBug + Lollypop maybe a good bundle Enrico
  • gregoryfenton
    0 gregoryfenton over 11 years ago
    You can add a battery to make it work without a USB connection.
    Using a battery adds its own set of problems, including one that can kill a Raspberry Pi.
    1: You need to hold A and B buttons for 10 seconds to reset the device so you can reprogram it over USB
    2: Connecting a CodeBug to a Raspberry Pi via the GPIO ports will kill the device if a battery is installed.
    0 e14 Contributor over 11 years ago in reply to gregoryfenton
    Connecting a Codebug to a Pi by GPIO and simultaneously powering Via USB killed a Pi, but I'm not sure that a battery powered codebug will damage a Pi, I would suspect it would be OK.
    The USB powered codebug fed 5V into the Pi's 3V3 GPIO, a 3V CR2032 won't kill the Pi.
    The CR2032 may be damged by this process.
  • notdodgy
    0 notdodgy over 11 years ago
    Lollipop stick would do it...
    0 balearicdynamics over 11 years ago in reply to notdodgy
    CodeBug + Lollypop maybe a good bundle image
    Enrico
