microbit
  • microbit
microbit
micro:bit Blog Struggling to learn--GEMS
  • Author Author: lrjones
  • Date Created: 20 Oct 2018 3:13 PM Date Created
  • Views 956 views
  • micro:bit education giveaway
lrjones
lrjones
20 Oct 2018
AM preparing for the all-day GEMS camp where we will use and give away the microbits. Am terribly frustrated by software--can't find the block for IF-DO--and you can't do much without that!
Tried to make them work on tablets, but not having much luck there.
Does anyone know how to find/get this block in logic in MakeCode?
Note: three hours later ( I am determined) we are going to use MakeCode anyway--old computers don't have the bluetooth. Will just tough if out. I thik that maybe the code has changed.
I have four activities planned--the girls are very excited!
  • jc2048
    jc2048 over 8 years ago +3
    I don't understand what you mean by an IF-DO block. Do you mean a conditional, IF <something> THEN <do something> type construct? If so these are your options [they're called 'Logic' for some reason] Or…
    dougw over 8 years ago +3
    The if-then and if-then-else blocks are under the Logic functions... IF-Then is similar to If-DO
  • jc2048
    Or do you mean a WHILE <something> DO <something> style loop, in which case these are your options
    If you're more used to using a traditional programming language and know Javascript, change to the Javascript view, write a bit of code and then swap back to the blocks and it will show you what the block equivalent is.
  • jc2048
