STEM Academy
STEM Academy
Documents What Do I Need to Teach STEM? STEM Educator and Wishlist Giveaway
  • Author Author: e14phil
  • Date Created: 10 Aug 2021 12:44 PM Date Created
  • Last Updated Last Updated: 2 Mar 2022 9:30 AM
  • Views 5059 views
  • Likes 19 likes
  • Comments 23 comments
What Do I Need to Teach STEM?image
Summer is wrapping up in the northern hemisphere, and students are heading back to school. The U.S. Bureau of Labor Statistics (BLS) 2019–29 employment projections show that occupations in the STEM field are expected to grow 8 percent by 2029, compared with 3.7 percent for all other occupations.
Clearly STEM is an important and in-demand field of expertise, so get your students started in the world of engineering by introducing them to the tools and building blocks that are used to design the devices that we use every day.
We've put together a wish list with all the fundamental items needed to help you educate the next generation.
STEM Giveaway
STEM Giveaway Prize
  • Duratool Digital Multimeter
  • BBC micro:bit Club Box set with 10x micro:bitsimage
Questions:
1) Engineers, tell us about your favorite teacher, and why they were your favorite
2) What item are we missing from this list?
Terms:
Post your answer as a comment below between 3rd September 2021 and 15th October 2021.
The best answers will be chosen by the element14 community team, and you will be shipped your prize (or local equivalent) free of charge.
List of Items:
The Basics
Computational Thinking
BBC micro:bit
Teaching logic and computational thinking is the first step for many children into a life of engineering of any kind. The BBC micro:bit comes with educational lesson plans and is a great teaching tool for any level.
We also have our own BBC micro:bit v2 resources in the dedicated micro:bit space.
Single BBC micro:Bit
BBC micro:bit GO
10 x Club STEAM Set
10 x BBC micro:bit set
Measurement and Power
Multimeter – An electrical engineer’s best friend. A multimeter reads voltage, current, and resistance, basic measurements that are important in any circuit.
Bench -
Multicomp Pro 3.7" Bench Multimeter
Handheld -
Duratool Handheld Digital Multimeter
Oscilloscope – Electrical measurements aren’t always fixed; some of them change with time! An oscilloscope maps electrical signals against time. Pair it with a function generator to see the difference between a sine wave and a square wave, or plug a capacitor in there and watch those square waves turn into shark fins!
Digital Oscilloscope -
Multicomp Pro Digital Oscilloscope
Handheld Oscilloscope -
Function Generator – A function generator creates different waveforms at different voltages. Function generators generally allow you to specify voltage, frequency, and the type of waveform. Very useful in learning about AC power, audio, clocking, RF, and more.
Function Generator -
Bk Precision Function Generator
Bench Power Supply – A digital circuit might require 5V, while an analog audio circuit might require +/-15V. A bench power supply makes it convenient to jump from project to project, even when the voltages are different.
Bench Power Supply
Multicomp Pro Bench Power Supply
Building Circuits – The Basics
Breadboard – Breadboards let you quickly wire up a circuit without having to solder wires. Simply plug wires into the right holes and they’re connected. Breadboards also have rails for power and are compatible with ICs (integrated circuits).
Breadboard -
Multicomp Breadboard
Jumper wire – Don’t skimp on wire; you’ll need a lot of it! Make sure you have a variety of colors, because no one like to debug a circuit when all the wires are the same color and can't be easily told apart.
Jumper Wire Kit -
Multicomp Jumper Wire Kit
Components
Passive Components
Passive components are components that change the power flowing through a circuit, but do not require power themselves. Passive components include resistors, capacitors, inductors, and more.
Semiconductors – Discrete
Semiconductors come in two varieties: discrete and integrated circuit. A discrete component is a component with just one circuit element. Passive components like resistors and capacitors are discrete components; however, there are also active ones, like transistors and diodes. These serve multiple purposes, from switching to amplifying and more.
Semiconductors – IC
Integrated circuits are chips containing multiple components. ICs are incredibly advanced, with analog and digital chips designed for a wide variety of purposes. Examples of analog chips include audio op-amps, filters, and amplifiers, while digital chips can run the gamut from a simple NAND logic gate to the most advanced FPGA (Field Programmable Gate Array). Simple logic gates are ideal for teaching the fundamentals of digital circuits.
Op Amp – an op amp is a high gain electronic voltage amplifier. They are used in many devices, ranging from consumer to industrial. An MC1458 is a commonly used dual op amp.
Op Amp
Quad NAND Gate – a NAND gate is an example of a digital logic gate. A NAND gate returns a 0 only if both of its inputs are 1.
Nexperia Quad NAND Gate
OR Gate – an OR gate is another type of logic gate. An OR returns a 1 if either input is 1. If both are 0, it returns a 0.
Logic OR Gate
555 Timer – A 555 timer generates a pulse that is useful for many applications, but for simple digital circuits, it works wonderfully as a clock to keep everything running.
555 Timer
Interfacing with the Outside World
Now that you’ve got the pieces to build a circuit, you’ll need some components that let the circuit do something, whether it be turning on a bulb, reproducing audio, or running a motor.
Switches – these turn things on and off, whether it be power, an LED, or turbo mode on your robotic vehicle.
Rocker Switch -
E-Switch Red Rocker Switch
Toggle Switch -
Eaton Toggle Switch
Potentiometers Overview – a variable resistor that lets the user adjust the level of a signal, for example audio volume or the intensity of a light bulb.
Wirewound -
Bourns Wire Wound Rotary Potentiometer
Slider -
Bournes Slider Potentiometer
LED – Light Emitting Diodes or LEDs are a great way to display what’s happening in a circuit. They come in different colors, and you can get them to blink.
LED Overview
LEDs -
Red LED Set
LED Array -
LED Array
Piezo buzzer – A piezo buzzer beeps when it gets voltage. They’re a great audio notification; remember the classic board game Operation?
PUI Audio Buzzer
Stepper motor – Motors are very versatile tools, and building a circuit to control one is a great learning tool. Whether the motor is attached to wheels or spooling an excess cable, motors let users immediately see what the circuit is doing.
Stepper Motor -
Stepper Motor
Sensors (inc Transducers) – sensors detect changes in the environment around them, and come in a tremendous variety of types, making pretty much any interactive circuit possible. Photo, magnetic, and vibration sensors make for great learning tools in the lab.
Photo sensor -
TT Electronics Optical Sensor
IR detector -
Sharpe Light Detector
Magnetic sensor -
Honeywell Magnetic Field Sensor
Vibration sensor -
Vibration Sensor
STEM Giveaway
As mentioned above, if you want to be in the running to win the giveaway mentioned earlier in this document, just answer these questions in the comments below:
Questions:
Terms:
Post your answer below between 3rd September 2021 and 15th October 2021.
  • competition
  • stem
  • microbit
  • introduction to electronics
  • giveaway
  • fmilburn
    fmilburn over 5 years ago +9
    My favorite teacher prior to university was Mr. Perry Regier who taught physics and chemistry at my high school. There are two things I distinctly remember. First, Mr. Regier did lots of demonstrations…
    dougw over 5 years ago +7
    Missing components: The sensors in the micro:bit help round out the list nicely. A force sensor might also be interesting, maybe a force sensitive resistor. I also like the servo motor suggestion. For…
  • rsc
    rsc over 5 years ago +6
    The logic gates you show above are surface mount devices - you will need DIP package devices or some sort of adapter for use with the prototyping board listed. Schmartboard sells some interesting circuit…
  • rsjawale24
    rsjawale24 over 5 years ago
    Any updates on the giveaway?
  • robogary
    robogary over 5 years ago
    Commenting on the updated list from Oct 12 2021 -
    In high school, I had a great time and learning experience with my chemistry instructor. He was an older fellow who was very big with hands on and live demonstrations.
    I really learned alot from his approach.
    There was one experiment setup as we came into class one day, with electrodes tied to a 115VAC plug, above a beaker of water, and a light bulb.
    I already had my ham license and knew a bit about electricity, and could see right away the point of his experiment before it started.
    Electrodes would be lowered into the beaker, salt was added to solution , the water would conduct and the light bulb would light.
    The experiment was close to my seat, so I playfully reached up and unscrewed the light bulb a turn.
    After dumping a bunch of salt in the solution, it took the instructor a minute or so to find the issue,  On this day, was my only trip to the principles office.  :-)
    Luckily, the principle was busy that day, at the end of the class period I was set free unharmed.
    Adding to my original submitted list, adding a small tools kit and PTC kit
    https://www.newark.com/duratool/spc10068/basic-electronic-tool-kit-22-pieces/dp/18C2428
    https://www.newark.com/epcos/b59003z0999a099/ptc-thermistor-kit/dp/29T3546?st=ptc%20kit
    Here are the essential components have that could be added (these parts are on my wishlist for teaching my classes at the library) :
    MicroBit Edge connector https://czh-labs.com/products/edge-connector-io-breakout-board-for-bbc-microbit-microbit-breakout-module?gclid=EAIaIQobC…
    9G servo  https://www.newark.com/multicomp-pro/mp-708-0001/servo-motor-180deg-rohs-compliant/dp/53AH7142
    HC-SR04P  the 3V ultrasonic ping sensor
    PIR sensor HC-SR501
    photo resistor - LDR
    WS2812 addressible LEDs   https://www.newark.com/dfrobot/rob0150/circular-rgb-led-exp-board-micro/dp/87AH9901?ost=ws2812
    5A  Buck Boost power supply https://www.ebay.com/itm/324158181983?hash=item4b7955525f:g:azIAAOSwMmhes0kH
    https://www.ebay.com/itm/194315743889?hash=item2d3e1ef291:g:PdIAAOSwk~Vcj1vd   H bridge
    DC motor https://www.ebay.com/itm/122046384255?hash=item1c6a88087f:g:LfAAAOSwielegv4T
    AAA 2 battery holder with switch https://www.ebay.com/itm/182738715576?epid=2212121056&hash=item2a8c1383b8:g:zowAAOSwGslg8p~X
    thermistor
    OLED matrix display    https://www.amazon.com/HiLetgo-Serial-128X64-Display-Yellow/dp/B06XRCQZRX/ref=sr_1_2_sspa?dchild=1&keywords=oled+display…
  • thespamcatcher
    thespamcatcher over 5 years ago
    Questions:
    I was fortunate enough to have had more than one great teachers in both high school and college.
    In high school I had at least two great math teachers. One for algebra and one for trigonometry.
    The trig teacher Was a woman that had worked as a drafts person working in an airplane defense plant during WWII. She would relate to us real stories of how and why we needed to understand each lesson. I still remember full sized (over 20ft long) drawing of a bomber body rib which she used for several lessons.
    An all around STEM education should cover many things, thus I relate a college professor I had for both history and physical geography. He was one of those guys that said we were tested only on what was in the book and gave out assignment that way, but during class, aside  from answering any questions on the subject, he would relate stories - behind the scenes - he used to say.
    In history he would tell us what was actually going on with the other people involved that were usually not mentioned much in the text. The intrigue involved in an often boring item in the text book.
    In the geography class he would tell us stories about how the land or boundaries got that way. Why countries or states were shaped the way they were. Background and happenings of things like the Lewis and Clark expedition and who made other discoveries.He added interest to boring facts. Did you know that they took air rifles along for hunting and protection? Not just BB guns either! They were very powerful and had a nice range.
    While there are many physical items that could probably be added, several have been listed, the main one I don't see is a guide or syllabus for each subject down to the lesson level. For those of us that are not trained as teachers or have been away from school for many years, that would be most helpful!
    For those that want actual items, I would say more motor types and how tubes and older tech fit into all of this new stuff. Maybe a little about why doing some of the stuff we can do today was possible(or NOT)  but not practical even just a few years ago. When I was a kid building a crystal radio was a great project, today a kid could build a software defined radio (SDR) with a little study and a few parts.
  • embeddedguy
    embeddedguy over 5 years ago
    Who was your best teacher? Why?
    There were many favorite teachers whose lectures I enjoyed. During school time a teacher who taught us scientific experiments inside a lab was my favorite. I always enjoyed practical subjects instead of only theory. He taught us some experiments like i.e. How to mix Alchohol with water and fire up a piece of cloth from the spectators in a live show (It appears that cloth is burning but it actually does not because there is water with Alcohol), Make small firecrackers buy putting water drops on sulfur stones and similar other experiments They really made science a fun subject with many things to learn.
    During my bachelor's time, I had joined a local community electronics group that makes projects and showcases them to students in schools. He taught us some circuit designs for example to make timers with NE-555 IC, OpAmp circuits, Ultrasound based vibration sensors, 433Mhz RX/TX modules for communication, etc. I actually learned how to solder and make PCB with tiny components etc. I think that there are a lot of capabilities of these small electronic projects/DIY projects to be used in daily life. I enjoyed the fact that the group was showcasing the projects to people who are unaware of the electronics world.
    During my Master's study in Germany, I attended a high-level course on Sensors. There was a Prof. who was well known in Germany for sensors systems research. In his lectures, I learned what are the recent trends in sensors and the development of MEMS sensors. Among all the teaches I have mentioned one thing was common that they made learning fun as well as stress-free instead of a burden on a student. At the same time, there were a lot of things we all learned from their lectures/practical sessions.
    There was also one more lecturer who was conducting FPGA Lab. Me(Indian) and my friends from Pakistan all there of us will sit in a lab together in a group, he would visit us to check our progress and answer our doubts. If there is some bug in a Xilinx Vivado HLS he would sit with us and start to find a solution. Suddenly if we come up with a solution and start to speak like...... (Me or my friend): Sir, I think...image (Lecturer): (high volume)Wait..wait..wait..wait......waaait!!, then in light volume, he would say the solution himself instead of letting us tell himimage
    What item is missing from the list?
    I think a Bench Multimeter is missing me. I have had several handheld multimeters but they eventually brock-up or the battery gets discharged which is tedious to change always after some time. The Bench Multimeter would be durable for years.
  • jpsantos1989
    jpsantos1989 over 5 years ago
    Thanks so much for having me guys. I am a new instructor at Orange Technical College Mid Florida Campus and I have the pleasure of educating our High School students in the Mechatronics Program. If I had to mention who was my favorite teacher it would be Mr. Henderson. He was my 10th grade Electronics teacher at Barbara Jordan High School for Technical Careers in Houston Texas, and here is why.
    We all know that in order to do well in electronics you got to have a good foundation in mathematics. In the 10th grade I took my first algebra course and my algebra teacher was very old school and very robotic in the way he taught algebra. It was all memorization a + b = c, a² – b² = (a-b)(a+b), a² + b² = (a-b)² +2ab etc..... To me the math did not make sense. In my head I could not wrap the concept of adding, subtracting, multiplying and dividing letters. So that first report card period I made an F. I clearly had no understanding of the concept, it just did not make sense and it was frustratingly confusing. I was thinking about dropping out and doing something else because I just could not do the math.
    The next semester I signed up to take my first Electronics course. Mr. Henderson was my teacher and he taught me the basics of electronics.  Taught me how to do circuit calculations, how to manipulate ohms law, watts, law, kirchhoff's law to solve for values in series, parallel and complex circuits. In essence he taught me, algebra. In the next report card period I went from an F to an A in my Algebra course. I went from not having an understanding to having a full comprehension of algebra. Thank you Mr. Henderson for making the math make sense.
    There are very few teachers that can teach you a concept and make it applicable in other parts of your studies. Those are teachers that affect you forever and I'm sure all of us here have that one teacher that affected us a similar way.  I strive to be like Mr, Henderson with my young High School students that I have today. Thanks
    As far as what we could add to the kit. I would have to agree with others in the chat. A good soldering iron would be nice.
    Respecfully
    Juan Santos
  • john.porter
    john.porter over 5 years ago
    My favorite instructor was Mr. Davidson, he was very knowledgeable and had a way of instructing that really resonated with me. And patient, which was a bonus when I was young(er) and could sometimes be 'off the chain'.
    The kit really needs an Arduino and Raspberry Pi. Perhaps a UNO and RPi3. Very inexpensive and essential for STEM in my opinion, besides you need something to help make use of all those other components! A soldering iron would be helpful as well.
  • colporteur
    colporteur over 5 years ago
    I've been monitoring posts and thinking, that was a great idea, wondering why I didn't think it. kmikemoo post altered my perspective to look at the kit from a kids perspective.
    Where is the really cool carrying case to keep all the stuff in? Maybe some flashing tech and soundimage added to make it stand out.
  • kmikemoo
    kmikemoo over 5 years ago
    I really wish that I could remember the names of some of my teachers, like my second grade teacher that understood that some kids need physical learning.  She must have let me play with the measuring cups and water table for hours - but I knew how many pints are in a gallon because I filled it up multiple times and made sure.  I never realized that she was setting me up for success when it came to multiplication and fractions.  My third grade student teacher was Mark Ferguson - that just took the time to listen to a hyperactive kid.  He became a family friend.  My 8th grade language arts teacher that passed me because I really did try my best.  SGT Larry Maldonado and SFC Albert Gomez of the USACE Prime Power School that taught me a problem solving process and (indirectly) that the points aren't as important as the understanding.  Very little in Engineering gives you partial credit.  As Master Yoda says, "Do or do not.  There is no try."
    What does the kit need?
    Battery holder  https://www.newark.com/element14/cy-bb2aaa-05/dual-aaa-batt-holder-micro-bit/dp/51AC1983 or https://www.newark.com/multicomp-pro/pe000054/battery-holder-dual-aaa/dp/81AC5243
    Case https://www.newark.com/kitronik/5606/protector-case-micro-bit/dp/29AC0391
    Relays  https://www.newark.com/multicomp/hrs1h-s-dc5v/relay-signal-spdt-120vac-24vdc/dp/97K1572
    Banana plug to grabber cord, Red  2 each  https://www.newark.com/pomona/3782-60-2/test-lead-red-1-524m-60v-5a/dp/10M4294
    Banana plug to grabber cord, Black  2 each  https://www.newark.com/pomona/3782-60-0/test-lead-black-1-524m-60v-5a/dp/10M4293
    Jan Cumps over 5 years ago in reply to kahocheng
    kahocheng  wrote:
    ... prof. em. ir. Willy Verstraete at Ghent University...
    Belgium !
  • kahocheng
    kahocheng over 5 years ago
    1) Difficult to choose, but I think I will choose prof. em. ir. Willy Verstraete at Ghent University, specialized in wastewater treatment engineering, as favorite teacher. He is very funny, always available to help students (fluidomechanical and electromechanical design, experiments and setup, results, resolve problems, encouraging even lots of things are going wrong...). Furthermore, he has always out-of-the-box ideas. He also tells us lots about the past as a young professor at the time, as well as lots of wisdom.
    2) I am a starter in electronics. The parts I think are interesting are:
         - Photo interrupter
         - Relais
         - Reed contact with magnets
         - Electromagnet
         - A small water pump or DC motor
         - Alligator clips or a breadboard connector to connect the micro:bit with external electronics/breadboard
         - Moist sensor
