Member and Staff Blogs Simple Passive Component V-I Curve Tracer
  • Author Author: fmilburn
  • Date Created: 1 May 2022 3:43 AM Date Created
  • Views 17134 views
  • Likes 12 likes
  • Comments 12 comments
  • capacitor
  • curve tracer
  • V-I Curve
  • diode
  • waveform generator
  • oscilloscope
  • led
  • function generator
  • resistor
fmilburn
fmilburn
1 May 2022
If you are like me you don't use the XY plot function on your oscilloscope often but it can be handy at times.  I was reviewing videos by W2AEW on YouTube and saw this one where he describes a simple method for viewing components using only a waveform generator and an oscilloscope.  The short (less than 3 minutes) video below demonstrates how it works.
The setup is quite simple.
Simple V-I Curve Tracer
The function generator produces a triangular waveform across the DUT which is in series with a shunt resistor used to measure current.  The oscilloscope in XY mode has the X-axis set to measure the voltage across the DUT while the current is displayed on the Y-axis.  There is a problem with this setup, however.  The X-axis probe is measuring the voltage across both the DUT and the shunt resistor.  This can be acceptable if the voltage drop across the shunt resistor is small.  Some oscilloscopes allow the math function to be used in XY mode so that the voltage across the shunt resistor can be subtracted from the DUT reading.  Mine does not.  Other approaches would be to use a differential probe for the DUT or a current sensing probe for the current.
My oscilloscope is a Keysight DSO-X 1102G which has a built-in waveform generator.  The waveform generator was set to 50-ohm output with a 3V p-p symmetric triangle wave.  To get a clean trace the acquire mode on the oscilloscope has been set to high resolution.
The screenshot below shows a red LED under test.
Red LED Under Test
Thanks for reading and comments are always welcome!
  • Andrew J
    Andrew J over 4 years ago +1
    I thought the quality was good. In fact, I actually thought the embedded video was from W2AEW and I spent some minutes scratching my head working out why your comment made no sense!! Great post.
  • fmilburn
    fmilburn over 4 years ago in reply to beacon_dave +1
    Thanks, I've corrected the typo. That is a good point about 50Ω output mode. I may remake the video when I get my new microphone - don't want to add any more confusion to the internet than is already out…
    beacon_dave over 4 years ago
    Another nice post.
    FYI you have a slight typo on the scope model number though:
    "...My oscilloscope is a Keysight DS)X1102G..."
    Some viewers may be confused by your 3V peak-to-peak voltage comments as the scope waveform appears to be showing 6Vpp ( although you do mention that the generator is in 50Ω output mode ). Would the Hi-Z output setting perhaps be more appropriate here as I've seen it used in the Keysight training materials ?
    Another nice post.
  • fmilburn
    Thanks, I've corrected the typo.  That is a good point about 50Ω output mode.  I may remake the video when I get my new microphone - don't want to add any more confusion to the internet than is already out there :-)  Here is a link to a Keysight video on Hi-Z for those interested:  Don't Fall Into This Output Impedance Trap! - YouTube
