Member and Staff Blogs Time to put up the Christmas lights - with a difference.
  • Author Author: Fred27
  • Date Created: 4 Dec 2022 11:22 AM Date Created
  • Views 4635 views
  • Likes 18 likes
  • Comments 30 comments
Fred27
Fred27
4 Dec 2022
I've not been as active as I'd have liked on E14 over the last year or so. That's something I hope to change. I've mainly been busy with a new job (with lots to learn), but also the change from Jive to Verint at the same time didn't help. Nothing felt quite in the same place.
Anyway, I feel it's time for something Christmassy. Something silly. Something fun. Something likely to fail, but that doesn't really matter.
I'm really not a fan of putting up Christmas light. We tens to hang then along the roofline of our house. It looks good, but it's high. I always end up standing at the very top of a long ladder, often with the top rung about knee height and my hand against the wall. It feels dangerous. Frankly, it is dangerous. Each year I swear I'm not doing it again. Time to get smart about it.
    Jan Cumps over 3 years ago in reply to Fred27 +2
    If you record the flight path of the drone this year, it can hang your lights *unsupervised* all the coming years. What a time to be alive.
  • Fred27
    Fred27 over 3 years ago +1
    Ok - so maybe some of you are wondering how it went. My first attempt was pretty close. I managed to get the string over the hook, but it was doubled over and came off again when I pulled the end I could…
  • ntewinkel
    ntewinkel over 3 years ago in reply to Fred27
    It was a very worthy attempt!
    I'm glad your drone is ok, and hope your fingers have already healed (I see that was nearly 2 weeks ago now).
    I was kind of thinking that while watching your earlier videos, if a long extendable pole might be able to reach the peaks instead of using the drone, and it looks like you made it happen Slight smile
    I avoided the peaks myself this year, and just stuck with the areas I can reach from my step ladder (my real ladder left me for another house when I was younger Wink).
  • robogary
    robogary over 3 years ago in reply to Fred27
    Very nice job. Good decision on the permanent installation, Murphy's Law states the the LED strings mounted at the peaks would fail after a year or 2.
    dougw over 3 years ago
    Pretty ambitious idea, but it will be awesome if you can figure out how to make it work.
  • Fred27
    Fred27 over 3 years ago in reply to beacon_dave
    I thought about that, but wanted the hook below the centre of mass so any downward pull would be less likely to cause instabiity. Maybe a longer hook would have helped.
  • Fred27
    We had the soffits repainted a couple of years ago. I thought about getting the lights permanently (but discretely) mounted, but decided against it.
    I'm sure the drone manual has a warning. I usually grab it from below rather than landing it. It's a good technique and this is the only time it went slightly wrong.
