Member and Staff Blogs Time to put up the Christmas lights - with a difference.
  • Author Author: Fred27
  • Date Created: 4 Dec 2022 11:22 AM Date Created
  • Views 4636 views
  • Likes 18 likes
  • Comments 30 comments
Fred27
Fred27
4 Dec 2022
I've not been as active as I'd have liked on E14 over the last year or so. That's something I hope to change. I've mainly been busy with a new job (with lots to learn), but also the change from Jive to Verint at the same time didn't help. Nothing felt quite in the same place.
Anyway, I feel it's time for something Christmassy. Something silly. Something fun. Something likely to fail, but that doesn't really matter.
I'm really not a fan of putting up Christmas light. We tens to hang then along the roofline of our house. It looks good, but it's high. I always end up standing at the very top of a long ladder, often with the top rung about knee height and my hand against the wall. It feels dangerous. Frankly, it is dangerous. Each year I swear I'm not doing it again. Time to get smart about it.
    Jan Cumps over 3 years ago in reply to Fred27 +2
    If you record the flight path of the drone this year, it can hang your lights *unsupervised* all the coming years. What a time to be alive.
  • Fred27
    Fred27 over 3 years ago +1
    Ok - so maybe some of you are wondering how it went. My first attempt was pretty close. I managed to get the string over the hook, but it was doubled over and came off again when I pulled the end I could…
  • Fred27
    I finally managed to get the lights up without the drone. I leaned out of the bedroom window with the string taped to the end of a very long drain rod, and hooked it over that way. I did the same at the other end of the house too. This is the final result.
    To add injury to insult, when sending the drone up to take that photo I managed to catch my finger in the prop and have 3 nasty slices out of my fingertip!
    beacon_dave over 3 years ago in reply to Fred27
    Sometimes the low-tech ways work best huh?
    Looks good lit up though.
    How long before soffits, fascias, bargeboards and window frames come with LED lighting fitted as standard I wonder.
    Does the drone manual advise on keeping fingers away from moving parts? Head bandage
  • Fred27
    Fred27 over 3 years ago in reply to beacon_dave
    We had the soffits repainted a couple of years ago. I thought about getting the lights permanently (but discretely) mounted, but decided against it.
    I'm sure the drone manual has a warning. I usually grab it from below rather than landing it. It's a good technique and this is the only time it went slightly wrong.
  • Fred27
