Member's Forum Switching with transistor versus relay
  • Replies 23 replies
  • Subscribers 632 subscribers
  • Views 2644 views
  • halloween ideas
  • relays
  • transistors
  • halloween project
  • motion sensors
jgrub
jgrub over 7 years ago
Element14 has a great YouTube vid on transistors, and I get that transistors are faster than relays and are better in low voltage situations. But I've been trying to custom build a motion sensor that remotely turns on the motor of an animatronic prop. It should be easy enough to activate that motor from the collector side of my transistor.
But because the prop is a distance away (maybe 5-6 feet), it has it's own power supply and a separate ground. All I really need is something to close the circuit on the ground side of the prop motor. So it seems to me that two wires from the prop to a remote relay, NOT a transistor C/E connection, would make more sense. The activated motion sensor would send 3.3v to the relay. Then the relay connects the two wires together and that completes the motor circuit.
I've been trying to do this with a transistor switch for days and can not figure out what I should be connecting to the motor two wires.
Has anyone else tried to rig a simple remote switch like this? (Halloween props typically use foot pads that complete the circuit in a similar but highly mechanical way.)
  • jgrub
    jgrub over 7 years ago in reply to jgrub
    I have a long video (28 minutes) that I made for my son, who is the recipient of my sharethescare  zombie lady, "Francesca". If anyone has a lot of time on their hands and is curious, this is a POST-construction user guide. https://youtu.be/N_I5-pm07PI
  • jgrub
    jgrub over 7 years ago in reply to 14rhb
    Thanks!!! I just sent "Francesca" to my son in Texas -- he's testing her now in his Hazmat House. But I've got sufficient documentation to share.
  • 14rhb
    14rhb over 7 years ago
    Hi jgrub
    Thought you might like to see that ShareTheScare 2019 - Halloween Project Competition has just been published...top prize is a 3D printer !
    I suggest you tag all your ghostly content with "ShareTheScare" so it gets picked up by the organisers.
  • 14rhb
    14rhb over 7 years ago in reply to jgrub
    Thank you image
    And if you need any help with the stepper/microcontroller - just ask.
  • jgrub
    Your pumpkin is so cool! I look forward to adding a step motor and microcontroller to a future project.
  • 14rhb
    jgrub I'm going to have to say 'gross' but I mean that in a good way image
    The main #sharethescare can be found  https://www.element14.com/community/community/halloween#sharethescare
    My entry was Peter the Pumpkin (part 5 - final thoughts) ....who is currently living in the loft/attic.
  • fmilburn
    fmilburn over 7 years ago in reply to jgrub
    Nice image
  • jgrub
    So here is the final product after settling on a PIR circuit (i.e. full integrated components included with sensor) and relay circuit (ditto): hanging zombie lady
  • jgrub
    I was not aware of sharethescare. Will definitely look into it and will share with my son. Thanks!
    genebren over 7 years ago in reply to jgrub
    Joe,
    Good that you have a path forward (relay) and path for the future/knowledge (transistor).  I thinking more about your plans and the scale of the motor (small vibrator), another approach that you might want to consider is a small solid-state relay.  This is very similar to your transistor approach, but something that might eliminate some design variables.  Something like https://www.newark.com/clare/cpc1002n/relay-solid-state/dp/03M7309?st=CPC1002  would give you the ability to switch up to 700mA of load, with no mechanical contacts (less cost, wear, etc.).  This could be connected to the output of your PIR, with a current limiting resistor inline and the output side could be used to complete the current path (much like your relay), with no need to tie the ground together.
    Just a note, be careful that the PIR has sufficient current output to drive your relay.  If the relay requires a higher current than the PIR can provide, you might need a driver between the PIR and the relay.  Also, be sure to add a protection diode to avoid damaging you PIR with the high voltage spike associated with the magnetic field collapse as the relay is switched off.
    Good luck!
    Gene
