Member's Forum Having sketch problems.
  • Answers 2 answers
  • Subscribers 630 subscribers
  • Views 747 views
  • new_member_introduction
I am having trouble with my sketch.  I am using an ultrasonic distance to activate relay.  Relay stays on all the time.
#define trigPin 12
#define echoPin 13
int relay2 = 2;
int i = 1000;
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(relay2, OUTPUT);
void loop() {
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
digitalWrite(2, LOW);
if (distance >= 25 || distance <= 2){
   Serial.println("Out of range");
if (i >= 4){
delay(i);
(distance >= 10);
(distance <= 8);
i = i/2;
  else {
   digitalWrite(2, HIGH);
   Serial.print(distance);
   Serial.println(" in");
    delay(i);
  delay(i);
i = i/2;
delay(2000);
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    So have a go at correcting the program based on my feedback above and then let me / the thread see where your at and we can help some more, we (The community and Top Members) try not to do it for you as then you will not learn much
    0 e14 Contributor over 11 years ago in reply to Robert Peter Oakes
    peter,
    HEre is what I am trying to do.  The relay activates water pump .
    0 Robert Peter Oakes over 11 years ago in reply to e14 Contributor
    So what the deal with the ever decreasing i variable then ??, can you explain what your doing with your code
    also there is a library for ultrasonic transducers that may make your life alot easier
    http://playground.arduino.cc/Code/NewPing
    http://forum.arduino.cc/index.php?topic=106043.0
    hope this helps
    Peter
    I Want the sonic distance to activate relay when distance is greater than 8" and  shut off relay when distance is 7".
    thank you.
    Im guessing he HIGH on the output energises the relay image
    I dont understand why you have all the DigitalWrite(2, low) and (2,high) statements the way you do, the relay if it is mechanical will never responsd that quickly
    these two statements seem obsolete as they do nothing
    (distance >= 10);
    (distance <= 8);
    and your comparison to i starts out with i=1000 and will not execute the relay pulse untill i<=4 so that means i/2 +2000ms delay each time as I goes from 1000 to 3 so thats about
    (1000, 500, 250, 125, 62, 31, 16, 8, 4) 9*2000 = 20 or more seconds before the relay will do anything
    Then your delays get so small due to using i and never resetting it once it gets to almost zero from 1000 that the relay will apear to sit energised or not depending what a High value on the output does
    So now we know the issues, what is it you really want the code to so, use a flow chart or plain english description (Not Code)
