Member's Forum Looking at parts and knowing what to do with them
  • Replies 9 replies
  • Answers 7 answers
  • Subscribers 634 subscribers
  • Views 1099 views
  • audio
  • howdoyoudothething
  • cluelessbuffoon
  • audioamplifier
  • amp
malus_lupus
malus_lupus over 8 years ago
I want to make an audio amplifier. I, of course, looked it up on youtube but I do not have all the parts however I do have a lot of parts. I have a lot of boards I have ripped parts off of. I am curious to how do I just look at a pile of parts and know what to use and how to use them to make an audio amplifier or anything else? I know people do this all the time but I have no clue how.
  • Fred27
    0 Fred27 over 8 years ago
    I'd start from the other end. Find a circuit you want to build and buy the components you need. If you can include some salvage ones then that's a bonus.
    Parts are not particularly expensive - especially when compared to your time and the effort you put into learning electronics. The pile of component you have in front of you are probably worth pennies. Don't attach too much importance to that.
  • stevenselder
    0 stevenselder over 8 years ago
    For a start, Take an OLDER Transistor Radio & Follow The Speaker Circuit back . The LARGE Boom Box or Cigar Box Size are easier to work with. You can use the entire PCB or cut off the R/F parts to save space. You can also use an old Tape CC Recorder PCB. Set to PLAY input would be tape head leads.
    If TOO MUCH gain, move in a Transistor or 2. Use series capacitor to block D.C.
    This "Reverse Engineering" will also assist you in Parts Identification. It also assures the parts are designed for audio use.
    Good Luck
    0 jw0752 over 8 years ago
    Hi Justin,
    There is no magic path to knowledge. I would recommend that you pick individual components that you have and then build something simple around that component. Data sheets often offer sample circuit suggestions that are a good place to start and offer a simple way to become more familiar with the part. As you build familiarity with parts you will find that you will reach back and find uses for what you have learned as you build future projects. Your salvage parts can serve as a resource but you will seldom be able to rely only on them completely for completion of a specific project. I always have to laugh when I watch Star Trek and everyone seems to be able to build an interstellar communicator by hooking random pieces of technology together.This is seldom the way the real world works. Make it fun to learn and embrace the challenges. We are all just like you though, we may be at different positions on the path to knowledge and experience. Go back and read the suggestions of   DAB , 14rhb , fmilburn , and genebren  as they have each given good insights as to where to continue your journey as it sounds like you have already begun by collecting assorted parts.
    • Vote Up +5 Vote Down
    0 genebren over 8 years ago in reply to malus_lupus
    malus_lupus,
    Something like LTspice (or any other spice based tool set) can be very useful to experiment with circuits to see how various components interact with each other.  You can take a basic amplifier design and substitute a different op-amp into the circuit to see how it works.  The more you know about electronics, the easier some of this becomes, but you can develop some of that understanding by reading and following the lead of other designers.  There are a lot of very interesting projects documented here on element14 that you can use to help you increase your electronics knowledge.
    Good luck,
    Gene
  • fmilburn
    0 fmilburn over 8 years ago
    I suggest starting simple - e.g. a single transistor amplifier.  Also, try a good book or if you prefer the internet for  a write-up of how transistors work rather than YouTube.  Here is an example (which I have not tried but there are many others):  https://www.hackster.io/jwzumwalt/single-transistor-audio-amp-32033a
    When you understand how the amplifier works then try to build something similar.  Many common transistors should work. The link above has the math for selecting caps and resistors.  If you don’t have the exact part then subtitute what you have.  Swap out parts and see how that changes things. You don’t need anything other than a transistor, battery, capacitor, and a couple of resistors to get started.  If you have problems then forums are a great place for help but I am guessing you can get something working pretty quickly and then start looking at ways to improve.
  • malus_lupus
    0 malus_lupus over 8 years ago
    The issue with that is I can look them up and get all the info I want but it still will not entirely help me connect the dot. For instance, I have a transformer over here I assume that could be helpful but I also hear about the transistors and I had no idea about them amplifying things I read it so if it amplifies the signal it is the thing to do. Then there is the whole you need to even out the signal which would be capped from what I hear, however resistors are sometimes involved and I am unsure of that and what values to use. I know about transformers if you rotate them around you can get amplification and such. Though I do not want to go with a huge transformer. I also have some bizarre parts that I know not much about that may could do something or may not. So basically I need to break it down. Signal in boost it, via what who knows yet, then that signal that is boosted output it to a smoother of some sort and then output put the smooth signal into a speaker of sorts. If it was simple it would be, signal in, transformer, some caps, and resistor, then attach to a speaker. However, it is not that simple from what I have seen. Got to get the proper resistors but I am unsure what I am even using them for, got to get the right caps I dunno even how to do that on a blank board.
  • 14rhb
    0 14rhb over 8 years ago
    Justin,
    If you haven't already done so then you may find it advantageous to identify some of the components you have stripped off boards, obtain the datasheet on them and also list them in an inventory. Then you could start to search the www on 'audio amplifier' plus the unique name of one of your amplifying components e.g. an IC or transistor.
    Rod
  • malus_lupus
    Ok, what software is advisable then? I can't go to college so that is definitely a bust. I watch videos on components and what they do but not all the components exist in those videos.
    0 DAB over 8 years ago
    Hi Justin,
    Your question highlights the advantage of an education in Electronics Engineering.
    With that education comes an knowledge of the existing electronic components and how to properly put them together to make circuits to do specific functions.
    Having a pile of parts may or may not provide everything you need for a specific circuit, but in engineering, we learn to do "close enough" compromises on components to get working circuits with acceptable defects.
    So a good engineer can make design circuits in many ways to do a specific function out of a wide variety of components.
    A good maker can in most instances follow basic cook book circuits and then adapt them to the components at hand. You just need to understand what the compromises are and how they affect the circuit.
    Using a Computer Aided Design tool enables engineers and makers the ability to look at the affect of using different components for a given circuit. So if you learn how to use these tools, you can get a good idea of how to use what you have to get what you want. Just be aware that there are no magic bullets. The more you learn about electronics, the more successful you can be.
    After 45 years, I still learn new things about electronic components and how to use them, so there is a good reason to keep current with the changing technology.
