    • Avnet Boards Community
Member's Forum Flashing Led's
  • Replies 53 replies
  • Answers 23 answers
  • Subscribers 533 subscribers
  • Views 4562 views
  • blink led
Flashing Led's
commanderkelly
commanderkelly over 6 years ago
Hello, I am new to this site and loving it. I did a bit of Electronics in 1995 where I made a flashing led circuit with 2 led's and it was cool. My other hobby is model trains and I would like to put 2 small led's in buffer stops and make them flash and run it off a DC train controller. Does anyone have a simple circuit that would do the job for this? I am basically a noob at electronics but I can follow a simple circuit.
Thank you.
Gary.
  • 14rhb
    14rhb over 6 years ago +12 suggested
    Hi Gary, Welcome to Element 14 Community. Although a long time ago, you have already completed the first step on the world of modern electronics - the famous 'blinky' experiment . I'm assuming you want…
  • beacon_dave
    beacon_dave over 6 years ago +8 suggested
    Probably can't get much simpler than a flashing LED: https://uk.farnell.com/c/optoelectronics-displays/led-products/flashing-blinking-leds Size may be an issue however. 3mm is the smallest listed.
  • fmilburn
    fmilburn over 6 years ago in reply to 14rhb +7 suggested
    Hi Rod and Gary, I am more of a digital guy but I saw this and had to build it. The circuit is close to the first link that Rod gave above. The voltage source is 4 AAA, R1 and R4 are 330 ohm, R2 and R3…
  • fmilburn
    0 fmilburn over 6 years ago in reply to 14rhb
    Great detective work Rod!  Good on you for for actually measuring frequency at higher voltage as I missed that.
  • fmilburn
    0 fmilburn over 6 years ago in reply to jc2048
    Great explanations Jon
    Frank
  • commanderkelly
    0 commanderkelly over 6 years ago in reply to 14rhb
    I will try this when I get some more stuff thanks.
    Gary.
  • commanderkelly
    0 commanderkelly over 5 years ago
    I have not been well for a bit but have not forgot about this project. I have now got one of them Ardunio Uno and was thinking of powering the flashing leds with it in the buffer stops. Now as I said before I am a noob at all this and I have no clue how to use an Arduino, Can anyone help me out here. I would like to power say like 10 flashing leds on differant buffer stops around the train track. Would this be possible on 1 Arduino and does anyone have a circuit that would help me do this.
    Thank you Gary.
    0 shabaz over 5 years ago in reply to commanderkelly
    Hi Gary,
    It can do that, there's an example for a single LED here:
    https://www.arduino.cc/en/tutorial/blink
    Once you've tried that, then you'll have confirmed the software and hardware is functioning, and then you can extend it to more LEDs to achieve your aim. Extending to flash two LEDs alternatively is easy by slightly modifying this code.
    However, it wasn't clear what behaviour you were looking for. If it is to flash all LEDs identically or flash all LEDs in alternate pairs, then the code doesn't need to change further, you can connect many LEDs to the same connections on the Arduino, although you'll need to use some small additional circuit to provide the current for all the LEDs. Is this what you're aiming to do?
    Otherwise, if your aim is to make them flash at different rates, or alternately, or under control of individual switches or sensors, then that will need more code changes.
    The easiest way is to start with the blink example mentioned, and then try a few more examples, to get familiar with the capabilities of the Arduino. Then you'll feel confident to want to do more complex behaviour for the LEDs (e.g. controlled by switches as mentioned).
    The tutorials here: https://www.arduino.cc/en/Tutorial/BuiltInExamples   will give you a feel for the capabilities of the Arduino (not all need to be tried, just a few that interest you).
  • SGarciaV
    0 SGarciaV over 5 years ago
    Hi Gary. I see that you've gotten lots of great responses. Personally, I am partial to the 555 :-D
    I recently built a circuit similar to the one described in the following video:
    https://youtu.be/gYnd_nMi39g
    As for the Arduino, once you have the board you need to install the Arduino IDE. You can get that at the following link:
    https://www.arduino.cc/en/main/software
    Two important settings of the IDE that *must* be correct are the serial port designation and the board type. There are lots of Arduino models, such as Uno, Nano, Mega, Leonardo and many more from other vendors. To get started, I would purchase one that is compatible with either the Uno or Nano.
    If the Arduino IDE is open, close it. Connect the Arduino to the PC via the provided USB cable. Note that the Uno uses a different cable than the Nano (for example).
    Once the Arduino is connected to the PC, the OS should recognize it and assign a serial port to it. Note that my experience and comments are in regard to a Windows installation.
    Now launch the Arduino IDE. Locate the settings for the port and select the port that was assigned to the Arduino that you connected. Also select the correct board.
    Go to the File menu option and open the Blink example. This is a really simple program, which in the Arduino world programs are called sketches, that blinks the internal LED. Once the program is open, click on the button to compile and download the sketch to the Arduino. If you get an error, check that the Arduino is connected and also check that you selected the correct serial port and board.
    Search E14 and Youtube, there are lots of tutorials to get you started. Here is one possible video:
    https://youtu.be/kLd_JyvKV4Y
    Sorry, at 37 minutes, I don't have time to watch it to comment on the video. Also search for Jeremy Blum's Arduino videos. Hopefully this info will be helpful to you. Good luck on your projects and welcome to Element 14, where everyone knows Ohm's Law! ;-)
  • commanderkelly
    0 commanderkelly over 5 years ago in reply to shabaz
    Hello and thank you I just want them to flash at the smae rate so for now this will do, thanks for your help.
    Gary
  • commanderkelly
    0 commanderkelly over 5 years ago in reply to SGarciaV
    Hello and thank you, I have the Uno board and downloaded the softwear to windows. I'll check them videos out thank you.
    Gary.
  • fmilburn
    0 fmilburn over 5 years ago in reply to commanderkelly
    Hi Gary,
    If you are OK with them flashing at the same rate and more or less synchronized then it is fairly straightforward  with an Arduino and will work just as Shabaz has described.  The circuit will be simple. There can be 10 output pins connected to the LEDs with current controlling resistors of say 330 ohms.  There could be 10 input pins for switching the behavior of the LEDs.  When a switch signals the start a timer can be used to determine how long the blinking occurs.  It is an interesting project.  Once you get things working as Shabaz describes then report back if it is not clear on how to proceed.
  • fmilburn
    PS:  it should be much easier with an Arduino than all the mucking about we did above :-)
