Member's Forum Brewing beer - Automate the mashing process - where to start???
  • Replies 12 replies
  • Subscribers 632 subscribers
  • Views 1417 views
  • help
  • rasberrypi
  • brewing
  • meshing
  • beginner
  • beer
Hi Folks,
My name is Sebastian, I am from Berlin, Germany, I have a degree in computer science and recently started home brewing beer :-) . Since this is not only a lot of fun but also a lot of work I wanted to start automate part of the brewing process. I did some soldering when I was 10-12 but never got any "real" project done.
So basicly I don't have a clue yet where to start but I hope to get support from this great community and a push in the right direction. I think of using an Arduino or an RasberryPi plus some relays and temperature sensors...
So here is what I want to do:
When it comes to brewing beer you want to controll the temperature of the brewing kettle.
For example:
- 15 minutes at 55 degrees celsius.
- Then go up to 64 degrees celsius, holding it for 30 minutes,
- then  go up to 72 degrees celsius, holding it fo 20 minutes
- finally go up to 78 for 40 minutes.
There can be up to 5 steps which can be programmed by the user for each beer recipe. I think there is already some software out there which runs on the RasberryPI and I think this is where I will have the least problems. But I totally suck at soldering, knowing nothing about how to attach sensors (which sensors???) to the RasberryPi, what voltage to use etc etc.
So, I don't want to study for 2 years elecronics, but lets say a month. Where should I start? Are there some great beginners tutorials which you can recommend?
Thanks for every tip,
Cheers,
Sebastian
P.S. I have one of these, which I want to modify and then would be controlled by the Rasberry or Arduino: http://www.amazon.de/Weck-Einkochautomat-2000-Watt-Emaille/dp/B000PKEZL0/ref=sr_1_1?ie=UTF8&qid=1372698539&sr=8-1&keywords=einkochautomat+weck
    0 e14 Contributor over 13 years ago in reply to DAB
    I'm not local to Dayton, and I probably wouldn't be much help with
    regard to quantum physics, although I welcome anything you might
    post on the subject, as I do have an interest in shared apertures.
    0 DAB over 13 years ago in reply to e14 Contributor
    Hi Sebastian,
    I am glad we were able to help.
    You might check the Hack a Day site.  They have a number of automated brewing projects they have collected over the years with a number of different microcontrollers.
    You never know when you can find someone who has already done all of the hard parts and who can provide some good lessons learned.
    Keep us posted on your progress.
    I admit, such a tale would indeed arouse suspision, even in a relaxed inebriated state.
    Still, a good tale is worth listening to, even if unbelievable it might still produce a modicum of entertainment.
    On a side note, if you are still in the Dayton area, send me a private message.  I am looking for good objective people to help validate my theory.
    Enjoy,
    Alas, I have never been to the Pine Club, so you clearly have me confused with someone else.
    Perhaps so.  It was probably around 1987, when oldtimers were still calling it Wright Field.
    He claimed to be buddies with John Elway, and had just recently bought his house.
    I seem to recall him trying to explain the difference between a register and a pseudo register.
    He claimed to be able to halt a processor by moving a pseudo register to itself.  Needless to say,
    I was dubious.
    Wow, thanks so much everyone. @Pete great links, thanks! @Coder I won't let it sit alone for days, more like 2-3 hours, so I am trusting DAB on this one ;-) and hope the RPi wont let me down so often.  Will report back here when I worked through the basics (@DAB and got my process well documented)  ;-)
    Cheers,
    Sebastian
    I guess some people do not appreciate the pleasure of a good story.
    Being of northern German descent, its in my blood to recall the sagas of old and explore the bounds of reality.
    It lightens the sole and enhances a nice evening sipping a good beer with friends and companions.
    Ah such are the days of legend.
    Come over to the Dark Side of the Force and I will open your eyes about the Universe.
    I actually think we met once at the Pine Club, during a NAECON conference.
    You were regaling me with all sorts of stories and I wasn't buying any of them.
    I am a man of many talents.
    I have also brewed Honey Mead, which was quite delicious.  I bake bread, take lightning photographs, research lightning, I am co-author on a US patent Application on Adaptive Algorithms, guided my office to a CMMI level II compliance, created a Hyperspectral Workbench, and a whole lot of things most of you will never hear about.  Did I mention my laser research?
    My Systems Engineering skills cover search and rescue control system for a helicopter coupled to a FLIR system to fly in 0/0 visibility levels, Integrated Avionics, and an Integrated EC test facility plus much more.
    Just a thought,
    but after 40 years in systems engineering
    Now you've got me puzzled.  I was led to believe your expertise was in
    naval war history, quantum physics, software adaptive algorithms,
    electro-optical sensors, and project management. and now you want us to believe
    it's in systems engineering? image
    Step #4:  If you are using a device outside its intended scope of application,
    find out it's MTBF.  If a controlling device freezes, it becomes incapable of controlling
    just about any process.
    Hi Sebastian,
    Step # 1, make sure you have a very stable brewing process.  If you can get the same quality beer each time you run the process, then you are ready to automate it.
    Step # 2, document the process steps, timing, temperatures, and other details so that you can design an automated process to duplicate the process.
    Step # 3, build and test.  Verify that the process works and validate that the beer is up to drinking standards, always my favorite part.
    As others have stated, the RPi was not intended as a process control, but after 40 years in systems engineering, I can tell you that it is more than capable of controlling this sort of process as long as you have a well defined process.
    So go define your brewing process and then post about how you intend to approach the process with an automated implementation.  We can then verify if you have all of the details covered and have an approach that might work.
    Until then, get busy, you have a lot of detail to document.
