how to make a image back from the compute module to external usb for backup / restore ?
I can successfully flashing the eMMC but dd command is not working in reverse.
The DD command will clone eMMC to USB bit for bit destroying the USB as you have above. Then Win32 utility can take USB and create a file of the same USB into a file name for backup.
Clem
PS a short cut would be to set of=/dev/sda1/backup.img to create a file on the USB. But that would be an unloaded version and not able to boot using USB which your original question implied.
I connect the USB thumb drive and use dd comand to backup eMMC in which if=/dev/mmcblk0 of=/dev/sda. This is exactly cloning the whole OS to usb drive. And then I use Win32 Disk Imager to read the usb thumb drive to save a img backup. Is it the correct way or any other method would be much more convenient ? (like making an image file from bootable floppy)
Firstly make sure you have "if=/dev/sd?" where ? is correct letter. No number is needed since you want the two or more partitions, right? You may want to read Instructions for Using the NEW Raspberry Pi Compute Module Development Kit for other ideas.
Clem
