Feedback and Support
F&S Forum Road Test Publishing Woes
  • Features & Improvements
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Sun, 07 Jun 2026 05:08:41 GMT ETag: "0x8DEBAF88819E20C" Set-Cookie: .te.csrf=SOgjwlhOrTU7TfFfF22LRMyNqALbf1-_oGyeTJRqCZU; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_u0wYfAFq4VKKCmcLhc6klgE%2fPRoKKbQsXMkwCuUO8nrei10AkQuADer%2bRWPcTk42pijOhYQ8C5k2oZHS7V98fvhhxOZ%2bjUif1W4y%2bmxd0ARVi9BmRyULZ4TRLjUnl4XPJxMrj%2bOyQvW5yGLgWECPFJwRuy982koQTGVIIUJu9NFqpOzDUIjil3CmjCzle3R9qr2vk5rtcjhIO8%2bYwbFjnQEI14NvZbWup2hnwMcqNxgS9GzwXK0wRn6gIOB9QrpGI5NchaH%2fE1EYfuWvn2IyFg%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=46 Server-Timing: ak_p; desc="1780808921177_34604941_238257623_7634_7496_6_6_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Replies 20 replies
  • Subscribers 17 subscribers
  • Views 3726 views
dougw
dougw over 4 years ago
In the past few days I have been having a bunch of problems publishing a road test. (Wurth Elektronik Sensor FeatherWing road test)
The first problem was it simply wouldn't upload the review. The "Post" button went gray and the little dots started cycling, but it just kept doing that forever, actually I gave up at 3:00 AM.
This review was just text - I was planning on adding in the video after it published.
The next day I rewrote the review and tried again, this time with an embedded video, which seemed to upload fine. However when I went to Post the review, it indicated that I was not permitted to upload a blog that was greater than 96 MB, so I deleted the video and posted the review.
Then I uploaded the video to a separate blog with no problems, but I cannot find the original review to edit or comment that the video is available elsewhere.
It seems I can no longer see or edit the review since it is already in review, whatever that means. I cannot find it on the forum.
I hate to disappoint the sponsors, but so far haven't been able to publish properly.
I suspect I could publish the review in a non-review area - maybe I will try that if the review really has disappeared.
Hold the phone... I think I just found it ... and I can even Post it. ...... trying to add in the video again....no luck 96 MB limit again.
/products/roadtest/rv/roadtest_reviews/1578/wrth_elektronik_sens_1
  • cstanton
    cstanton over 4 years ago +1
    colporteur reported the problem to Feedback and Support , here: /members-area/support/f/forum/50842/can-not-upload-files-greater-than-10mb-into-your-profile and I've raised it with the dev' team in regards…
  • cstanton
    cstanton over 4 years ago in reply to dougw +1
    Hm, okay so there's a functionality on the site admins such as myself can use called 'impersonate' where I can 'be' your account with your permissions and access. As you, I edited your roadtest review…
  • cstanton
    dougw said: When I drag the video into the review it uploads it fine, as normal, and puts it into the review. And if you upload it via the insert menu instead of dragging and dropping the video?
  • colporteur
    colporteur over 4 years ago in reply to cstanton +1
    Dragging and dropping images was a viable option for embedding content on the old platform. I am continually reminded on this platform that using that method is not a good practice if you want it to work…
  • cstanton
    cstanton over 4 years ago in reply to colporteur +1
    colporteur said: Dragging and dropping images was a viable option for embedding content on the old platform. I am continually reminded on this platform that using that method is not a good practice if…
  • cstanton
    cstanton over 4 years ago in reply to cstanton +1
    cstanton said: If it's not working 'the same' as inserting via the menu, that's something I'm investigating and will raise with the development team to make sure it's fixed. I've been able to replicate…
  • cstanton
    It should take only about 10 minutes. We may be seeing a problem here with video embedded into Roadtest Reviews in particular. Please have patience while I discuss this with the dev' team in America…
  • cstanton
    I edited and re-inserted the youtube video and it's now appeared, so this appears to be a permissions issue with regards to videos. The dev' team are still looking into it.
  • cstanton
    Yes, the other problem that was happening alongside it, is that there's a server automation in the background, that is meant to take care of this, and it was manually restarted about an hour ago and hadn…
  • cstanton
    colporteur reported the problem to Feedback and Support, here: /members-area/support/f/forum/50842/can-not-upload-files-greater-than-10mb-into-your-profile and I've raised it with the dev' team in regards to problems inserting videos into roadtest reviews.
    Are you able to insert the video after you've posted the roadtest review?
    dougw over 4 years ago in reply to cstanton
    No - when I add the short video, it still insists that the post is too big (bigger than 96 MB)
  • cstanton
    As you, I edited your roadtest review, and I was able to insert a video that was 30+ MB in size without an error message.
    Which means you should be able to.
    But the error message you received, was from the website.
    What web browser and extensions are you using? Perhaps it's miscommunicating with the site?
    Chrome - stock
    The 13 min video is 320 MB
    I uploaded it here without problems:
    /members-area/b/blog/posts/wurth-elektronik-sensor-featherwing-road-test---video
    It is only when I finally try to post/publish the review that the system complains about the size.
  • colporteur
    colporteur over 4 years ago in reply to dougw
    CS indicated I suffered the same problem. I recently went back and edited the post and it permitted me to add the video. I did chew gum, rubbed my belly and stood on one foot the first time but that doesn't appear to be the sequence needed to get past the door to publishing videos.
  • cstanton
  • colporteur
    Dragging and dropping images was a viable option for embedding content on the old platform. I am continually reminded on this platform that using that method is not a good practice if you want it to work.
    I will try tonight, although it seems to upload and insert the video fine, just refuses to publish the review.
    dougw over 4 years ago in reply to colporteur
    In the old system I uploaded to YouTube and embedded from that link. I don't think this works in the new system - When I try to embed from my YouTube channel, I just get a link not an embedded video.
  • cstanton
    It does work now, it was intermittently broken when we launched the site.
  • cstanton
    oooh... embedding from YouTube does seem to work now. It is still retrieving metadata but it did publish with a placeholder.
  • cstanton
    I've been able to replicate the problem. I've let the dev' team know how to recreate it.
    The YouTube method seemed to work but it is still "retrieving metadata" more than 12 hours later...
  • cstanton
    Please have patience while I discuss this with the dev' team in America.
  • cstanton
    Thanks, it wasn't happening without your help...
  • cstanton
    Yes, the other problem that was happening alongside it, is that there's a server automation in the background, that is meant to take care of this, and it was manually restarted about an hour ago and hadn't been running properly for 12+ hours, which also would have been a cause of the problem.
    The dev' team have raised this as an issue with Verint.
    Thanks for raising the problem.
