Member's Forum New and Exciting
  • Replies 73 replies
  • Subscribers 588 subscribers
  • Views 5859 views
  • exciting technology
New and Exciting
dougw
dougw over 2 years ago
What is the most exciting technology you discovered or rediscovered this year?
This is not a question about significant leading edge technologies, it is just about what you currently find exciting.
Are you into VR? Like Meta Quest 3 or Apple Vision Pro
Are you into computers? Like Raspberry Pi 5 or Apple iMac M3
Are you into e-bikes - a massive trend
Are you into Machine Learning? Like Huskylens
Are you into RISK V or FPGAs? Like BeagleV Fire
Are you into AI? Like CHATGPT
Are you into robots and automation? Like commercial drone applications or self-driving cars
Are you into communications technology? Like SDR
Are you into gaming technology? (and games)
Re you into retro electronics? Like vinyl audio or tube amps
Are you into test instrumentation? and setting up a great lab
Are you into software/firmware? Like RTOS or real-time LINUX on microcontrollers
Or all of the above?
What turns your crank these days?
What is on your wish list?
What courses do you need to take?
  • baldengineer
    baldengineer over 2 years ago +4
    This year, I started to learn how to use edge machine learning beyond face and voice recognition. Currently, I'm working on a small project that uses vibration to determine if a motor is running. (and…
  • stanto
    stanto over 2 years ago +4
    dougw said: Are you into VR ? Yeah, I bought a HTC Vive, original, back when bitcoin originally boomed some years ago, and this year since everyone's picking up the Quest 3 I was able to afford a Vive…
  • anniel747
    anniel747 over 2 years ago in reply to beacon_dave +4
  • scottiebabe
    scottiebabe over 2 years ago in reply to Jan Cumps
    Ohh no, does AMD follow Moore's law for install size too? Scream
  • beacon_dave
    beacon_dave over 2 years ago in reply to dougw
    Just solder leads onto them and turn it into a thru hole... Thinking
    Jan Cumps over 2 years ago in reply to beacon_dave
    attaboy :)
    (yes even BGAs. I saw Dave Vandenbout's video and never looked back. Will post it when I find it...)
    Jan Cumps over 2 years ago in reply to Jan Cumps
     -- I found the post but not the video:
    https://xess.com/blog/mounting-a-bga-on-a-pcb-quickly-and-cheaply/index.html
    ... here:
    He also has a video where he solders a bga by pushing a beefy solder iron to the bottom side of the PCB
  • strb
    strb over 2 years ago in reply to dougw
    I'm going to buy a waveform generator and thinking about a new soldering iron. My actual soldering iron is still working but it's somewhat limited in power. I'm planning to still use it, but as secondary iron for field use.
    I have an instrument wish list that I use as reference to keep track what I need the most. That's mainly to avoid buying stuff I don't need and to avoid wasting money. Unfortunately, after the function generator and the soldering iron prices in my list start to go up, so I have to keep my need for new shiny instruments under control Slight smile
  • BigG
    BigG over 2 years ago
    After many years playing with wireless technologies, such as sub GHz ISM, Bluetooth, WiFi, GSM/GPRS/LTE/4G, NFC etc. I have now recently switched back to communication technologies (and protocols) over wire.
    We tend to take protocols like RS485, RS232 & even Ethernet (TCP/UDP) for granted but I am discovering other options like narrowband and broadband powerline communication technology (including G3-PLC and HomePlug specifications) as well as single pair Ethernet. I had always assumed this only worked over mains power, but I quickly learnt that this is not the case at all. So there is plenty to explore and play with here, without the fireworks (sparks).
  • BigG
    BigG over 2 years ago in reply to stanto
    Speaking of oscilloscopes, I see there is now a road test open for the Digilent Analog Discovery 3 kit. I recently purchased a similar type of kit and they are ever so useful. These kits are also a good way to learn without have to spend thousands.
    dougw over 2 years ago in reply to Jan Cumps
    Nice, but still scary...
    Jan Cumps over 2 years ago in reply to strb
    Soldering iron, a meter and a power supply will be the things you'll use for 91% of the time.
    Get that house cozy and warm. The rest will follow.
