    • Avnet Boards Community
Member's Forum What's inside a 20+ year old dimmer switch?
  • Replies 30 replies
  • Subscribers 542 subscribers
  • Views 4159 views
scottiebabe
scottiebabe over 1 year ago
Not much. The dimmer function failed and only the switch function remained functional.
The schematic is the same as drawn by this author:
The Quadrac (an internally triggered triac, a triac + diac) failed short between all three terminals.
Searching for an X25783 datasheet led me to this,
https://images.100y.com.tw/pdf_file/31-Teccor-Quadrac.pdf
A more common brand that may be similar could be the
https://www.littelfuse.com/media?resourcetype=datasheets&itemid=b4817091-0710-4ac7-a446-a7ffcca0a634&filename=littelfuse_thyristor_q6008lth1led_datasheet.pdf
The potentiometer used as a rheostat has a switch stacked on top.
Not much inside...
  • scottiebabe
    scottiebabe over 1 year ago in reply to dougw +4
    Thankfully its all good news stories. If any fault current went into the earth ground of the mounting box a GFCI breaker would trip. I have never tried or played with Arc Fault breakers (AFCI). I may…
  • robogary
    robogary over 1 year ago +4
    The nice thing is they only stay short briefly if there is a bolted fault :-)
    dougw over 1 year ago in reply to scottiebabe +3
    Amongst the mayhem lies a nice fail-safe design. Nobody got electrocuted and the house didn't burn down.
  • scottiebabe
    scottiebabe over 1 year ago in reply to anniel747
    I wonder what the AFCI button does...
  • anniel747
    anniel747 over 1 year ago in reply to scottiebabe
    [deleted]
  • scottiebabe
  • scottiebabe
    scottiebabe over 1 year ago in reply to scottiebabe
    A different tester ct80
  • electronicbiker
    electronicbiker over 1 year ago in reply to scottiebabe
    Hi scottiebabe, sorry about the misunderstanding - I thought you were Scottish and lived in Scotland!
    So, ok, the 1.5mm gap should be fine at 110v. But I've just thought of something else...  Over a long period of time, soldered connections (especially when close together on a PCB) can exhibit a strange phenomenon caused by 'creepage'. This is where a soldered connection through holes in a PCB (amongst other places) will produce radial hair-like dendrites growing in length across the surface of the PCB. If they meet dendrites from another soldered connection then there may be trouble! I have seen solder connections where dendrites have grown all around them, looking like multipointed stars with very sharp points. The sharp edges around the ends of the through-pins used for connecting the two sides of a double-sided PCB are quite good at dendrite-growing, and an electromagnetic field helps to 'steer' them. Such as the ones produced by inductors.
    This is not a very common failure mode, but it can happen. If anything much more than a small current passes along a dendrite it immediately blows just like a fuse, thus destroying the evidence. One place where they might have formed is between two of the rivets holding the terminals in contact with the track on the pot.
    A lot depends on the age of components and PCB material. Conformal coatings on PCB's will usually prevent creepage effects.
  • electronicbiker
    I do like that oscilloscope! Might even get one myself to replace the ages-old Tektronix battery portable. Does it have BNC sockets for X, Y, and external timebase inputs?
  • bradfordmiller
    bradfordmiller over 1 year ago in reply to electronicbiker
    It's my understanding that 20+ year old electronics would have lead/tin solder, which generally would not form tin whiskers (unlike lead-free solder). REALLY old solder (think 1920s) did have whiskers, either because there wasn't enough lead or too much.
    Lots of LED lights don't work well with dimmers either.
  • md_steve
    md_steve over 1 year ago in reply to scottiebabe
    My homeowner insurance company is involved with a company that monitors your electrical system to watch for various faults. They claim to find all manner of physical issues from open neutral wires to arcing wires. Obviously their intention is to minimize electrical fires, which I think is a very good idea. I wish I'd had this service twenty years ago!
    For the curious, It's State Farm and Whisper Labs ("Ting"). So far it's only warned me that I've had power interruptions, which I find more useful than the old 'quarter on the ice cube tray' method.
    Jan Cumps over 1 year ago in reply to electronicbiker
    It has BNC inputs for channel 1 and 2. Not for external timebase.
