Member's Forum NZ Earthquake
  • Replies 36 replies
  • Subscribers 632 subscribers
  • Views 2883 views
NZ Earthquake
mcb1
mcb1 over 9 years ago
Guys/Gals
Just a quick update on the major Earthquake that struck NZ north of Christchurch just after midnight.
They have decided that there was two quakes and they are still deciding if it was along the Hope faultline which runs SW to NE and forms the hills that are between the Southern Alps and the east coast.
It would seem that this triggered many others right up the North Island so the effects were felt widespread.
I'm in Chch and was up at the time. It went on for 2-3 mins which is much longer than the previous ones.
The closest place is Kaikoura and it has caused some damage to houses, but has currently cut the road link that goes up the east coast (State Highway 1), and damaged other roads that could form an alternative route.
There was a Tsuanami warning issued, but got downgraded to a coastal warning.
Unfortunately these warnings end up much less than predicted, so if we actually get a real one, then I'm afraid many will ignore it.
For those that haven't experienced Earthquakes, they can be very disturbing to some people.
There is often little/no warning and while it might be a little bit of shaking at first, you have no idea how long it will last, or if it will get worse.
NZ sits on the junction of two plates and one is going under the other. The movement is constant, but various bits get stuck and then suddenly release as the stress overcomes the friction.
This release often results in extra loading on another part and triggers an aftershock which can be almost as large.
So far there have been 50 or more aftershocks in and around the area, so you get no rest from them.
GeoNet - Quakes
As you can imagine you lose power, your house gets trashed and you get no rest, so it's quite stressful in the affected are.
The christchurch event in 2010 had around 14,000 aftershocks varying down to only just detectable without instruments.
So this will last for some days and it may trigger more events.
If you have friends and relatives in NZ, do try to make contact but appreciate that cellphone systems get overloaded and texts are the best way to contact them.
Cheers
  • ntewinkel
    ntewinkel over 9 years ago in reply to mcb1
    The effects here are mild shaking, and little or no actual damage.
    That's good to hear image
    I guess it makes sense - we get the occasional quake near Vancouver Island and we barely feel it when it's that same sort of distance.
    ...predicted to lift the west coast by 8m
    That's a huge shift! The pictures of the 2 meter shift are already impressive enough.
    We also have ongoing worries about "the big one" (Cascadia Subduction Zone, I think) that's supposed to do some nasty things. Not sure if my island will sink or rise in that case... I might end up with waterfront property if is sinks! image
    Lots of discussion about liquefaction here too - I think we are learning from what's happening with you guys in NZ there.
    The theatre here had some seismic upgrades done to deal with the possibility of liquefaction - it's built right beside the river. Lots of sand in this area too.
    Cheers,
    -Nico
    mcb1 over 9 years ago in reply to ntewinkel
    Are you guys doing well? Did you have a lot of fixing and cleanup to do?
    Where are in Chch, which is about 150km south of Kaikoura.
    It does trigger emotions in some people that experienced issues in the Chch quakes, as you don't know how big or how long it will last.
    Ever since I've been alive they talk about the Alpine Fault (which formed the Southern Alps) going off, and that generates 8.2 - 8.5 quakes and is predicted to lift the west coast by 8m. Hence once you know where they originate, there is some relief... until the next very large aftershock.
    There has been some damage due to liquifaction ( Liquefaction information  ) in Wellington as some out it is built on the seabed which rose in the 1829 quake.
    I found this https://koordinates.com/layer/4068-wellington-region-liquefaction-potential/ which shows the potential effects.
    Now bear in mind Wellington didn't get hit, it was some distance form the initial quake but closer to the aftershocks and in the line of the faultlines for that area.
    Cheers
  • ntewinkel
    Wow, that's a huge movement all in one shot.
    Bummer for the folks in the first pic that they built their house right over the fault line!
    -Nico
  • gadget.iom
    gadget.iom over 9 years ago in reply to mcb1
    That last photo looks like an early apple-maps screenshot. image
    Those photos are amazing and scary at the same time.
    mcb1 over 9 years ago in reply to COMPACT
    Correct.
    You win the prize of as many Paua as you can legally collect.
    Paua and Crayfish (think Rock Lobster) are a staple fishery source in Kaikoura, and it attracts people from up and down the east coast to pop into the water to collect a feed. Without breeding stck the fishery will die.
    Thankfully the local fisherman have been actively removing them and placing them back on the rocks that are covered at low tide.
    This is a delicate operation as they are basically a very large muscle and any nick will kill them.
    They slither along the rocks so dropping them into the water and landing shell side down is also a death sentence.
    Along with paua they have also been rescuing fish stuck in pools and the odd crayfish which aren't used to being up on 'land'.
    I also found these images taken further up the coast.
       Look closely at the horizontal and vertical displacement where the driveway used to go past the house.!
      image image
    You can see that from this point (about 30km north of kaikoura) back toward kaikoura, the land and seabed has risen 2m.
    That isn't Helicopter window distortion, it the same piece of displacement.
    Credit goes to the photographers and NBR list them on their post.
    https://www.facebook.com/NBROnline/?hc_ref=NEWSFEED
    and these guys
    https://www.facebook.com/NelsonMarlboroughRescueHelicopter/
    Cheers
  • COMPACT
    COMPACT over 9 years ago
    That Paua photo is amazing!
    Paua is indigenous black abalone and is sold in NZ "Fush & Chup" shops as deep fried fritters. (Yum! I should pop on over to have some along with some Terakihi.)
    The inside lining of the shells are made into colourful jewellery commonly for Tikis and other souvenirs.
    DAB over 9 years ago
    Hi Mark,
    When I heard the news I was worried about you, but figured it  would be better to wait because I did not know how much impact there was to your infrastructure.
    Glad to hear that you and your family are safe.
    From what I have seen, the damage is pretty bad in some places, but all in all, it looks like NZ survived with minimum casualties.
    Let us know if there is anything we can do to help.
  • michaelwylie
    michaelwylie over 9 years ago
    It's always amazing how strong these can be. Glad to see you are O.K.
  • ipv1
    ipv1 over 9 years ago
    Glad to hear you are OK.
    Earthquakes can be terrifying and we in India are no stranger to quakes. I make regular trips to the mountains and landslides and falling boulders are unfortunately a regular scene however they are every bit scary each time.
    Its always better to be prepared and I hope you guys dont face any serious events.
    Stay safe and keep us updated.
    Cheers,
    IP
  • element14Dave
    element14Dave over 9 years ago
    Mark,
    The whole element14 team is relieved  to hear that you are safe. Thanks for sharing!
    Dave
