Legacy Personal Blogs 4 Bit ALU
  • Author Author: timswift
  • Date Created: 5 Nov 2016 12:33 AM Date Created
  • Views 1836 views
  • Comments 10 comments
  • 4 bit
  • transistor
  • alu
  • computer
  • diy
  • cpu
4 Bit ALU
timswift
timswift
5 Nov 2016
This is my 4 bit test ALU.
It has 6 functions, Add with carry, Subtract with carry, Shift Right with carry fill, AND, OR, and XOR.
While assembling the ALU I made some errors two of them being with the adder carry chain being wired backwards (MSB to LSB)
And the same with the shifter; wired to left shift instead of right shift.
It uses 181 transistor's and I am currently constructing the full 8 bit ALU which will contain 346 transistor's.
A photograph with labels:
   The small Mux is to select the carry out from ether the adder, shifter, or the carry In.
   The inverter mux selects between invert or pass (used to select subtraction/addition).
Tim
  • phoenixcomm
    phoenixcomm over 9 years ago +3
    I LOVE IT.. somebody with more patience than I. I worked for Interdata 76 - 78. In 1980 I built a 16bit Z-80 out of AMD-2901 4bit slices. I also added more register sets. Back in 68 I also did something…
  • phoenixcomm
    phoenixcomm over 9 years ago in reply to timswift +1
    timswift ts a piece of cake! You just have to have the right tools, and wire for that matter. Don't try and wire wrap without a wire wrap gun. You just have to practice a few times. Wire: 30 AWG (very…
    DAB over 9 years ago
    I admire your patience in putting all of those wires in.
