Legacy Personal Blogs BeagleBone - Cross Compile c++ on Windows
  • Date Created: 31 Jul 2016 3:53 PM Date Created
  • Views 5107 views
  • Likes 8 likes
  • Comments 7 comments
  • cross_compile
  • cortex
  • BeagleBone
  • beaglebonegreen
  • arm
  • ds-5
  • feature_tutorial
  • toolchain
31 Jul 2016
How to cross-build BeagleBone c++ sources to Linux executables.
The process isn't difficult, but there are some traps that I'll review here.
Software Requirements
  • ARM DS-5 development environment
  • Linaro GCC ToolChain
  • 7-Zip or another extractor that can create symbolic links
  • Temporary admin rights on your Windows computer.
(assuming you have WinSCP, PuTTY and the drivers for your BeagleBoard running)
Install DS-5
The community edition is ARM's free Eclipse-based IDE. Download and install.
After the download, you don't have a toolchain yet.
It's not hard to find GNU ARM compilers for bare metal. But getting a linux cross-compiler took some internet crawling.
Install Linaro cross-compiler Windows -> Linux ARM
Download a suitable archive.
For DS-5, I select a mingw32 hosted one with arm-linux-gnueabihf signature (big endian hard float).
The Debian image I have loaded is the latest at the moment I write this blog:
BeagleBoard.org Debian Image 2016-05-13
Linux beaglebone 4.4.9-ti-r25 #1 SMP Thu May 5 23:08:13 UTC 2016 armv7l GNU/Linux
It has the following gcc on board:
g++ (Debian 4.9.2-10) 4.9.2
The version of the toolchain that gave me the best compatibility with the Debian image is
gcc-linaro-4.9-2015.05-1-rc1-i686-mingw32_arm-linux-gnueabihf.
It can be downloaded from here: http://snapshots.linaro.org/components/toolchain/binaries/4.9-2015.05-1-rc1/arm-linux-gnueabihf/gcc-linaro-4.9-2015.05-1…
Although the remainder of the blog always shows me using gcc 5.3.1, I switched down to 4.9.3 on Windows because my BB linux install didn't have all the libraries, and for this blog I wanted to stay as close to what's on the BB as possible.
Once downloaded, extract the tar from the tar.xz using 7-Zip (it's as easy as right-clicking on the .xz file and selecting "extract here").
read this!
for the next action, take care that you start 7-Zip as administrator.
Failing to do so will give you a corrupt toolchain install.
Without admin rights, 7-Zip can't create the symbolic links (just try it and check the log).
The result is that when you build your projects later, the linker will fail to find standard libraries.
You'll get cryptic messages like this.
libstdc++.so: file format not recognized;
Start 7-Zip as Administrator.
Open the .tar archive that you've generated in the previous step.
Press the Extract button. Navigate for the location where the toolchain can be saved.
That's it. The compiler, assembler, linker and other goodies are now installed.
Configure the Toolchain in DS-5
Start DS-5, and navigate to Window - Preferences menu.
Search DS-5 - Toolchains
Press the Add button, and navigate to the folder where you've just installed your chain.
(for me: D:\users\jancu\Documents\elektronica\arm\linaro\gcc-linaro-5.3-2016.02-i686-mingw32_arm-linux-gnueabihf)
Apply your changes, and restart DS-5 when asked.
Create a Project
This is what we've been waiting for all the time. Get our first project up.
Select File - New - C++ project
Select the Hello World C++ Project, and click the toolchain that you've just installed.
Press Next, and be inventive in the next screen.
Press Finish. Your project is created.
Right click on your project and build it.
If you followed these steps, you'll get good news:
Deploy and Run
Upload the binary file to your BB's home folder (do a binary transfer please) with WinSCP.
You can find thefile in the debug subfolder of your project.
(on my pc: D:\users\jancu\Documents\DS-5 Workspace\bbb_gnu_linux_cpp\Debug)
Log on to your BB via PuTTY. You should land in your home folder.
make the binary executable by launching this command:
chmod +x bbb_gnu_linux_helloworld
execute it by running:
./bbb_gnu_linux_helloworld
If all is right, you should see the output on your terminal.
Thanks for playing!
BeagleBone - First Little Checks
BeagleBone - Show XWindow Graphic Apps on Windows Desktop
BeagleBone: Build and Debug a Linux C++ Program with Code Composer Studio
BeagleBone: Develop and Debug with Derek Molloy's GPIO Lib and Code Composer Studio
    Jan Cumps over 10 years ago in reply to balearicdynamics +3
    The live video is taken with an iPAD 3 Screen capture with CAMStudio, Fixed Region 1280 * 720 , to have wide screen, but code readable Cinepak-codex Record Audio from Microphone iPad and CAMStudio snippets…
    balearicdynamics over 10 years ago in reply to Jan Cumps +2
    Great Job Jan! In my opinion the video is perfect. I saw some tutorials that really are live, but for a lot of reasons not last the delays in the computer steps are very annoying. Better come scene changes…
    Jan Cumps over 10 years ago in reply to balearicdynamics +1
    (most challenging is doing it off the cuff in a different language. Having to think about what I'll say, speak a foreign language, explain technical things, without prep, is causing the most hick-ups during…
    Jan Cumps over 7 years ago
    For Code Composer Studio aficionados: BeagleBone: Build and Debug a Linux C++ Program with Code Composer Studio
    Jan Cumps over 9 years ago
    BeagleBone XWindow applications showing on my windows desktop via a remote XWindows session.
    I used Cygwin as the xwindows client on my laptop.
    run Cygwin's XWin Server
    open an xterm in the startx icon on the taskbar
    secure shell into the BB
    ssh -XY jancumps@192.168.1.5
    Then enter password, and fire up some apps:
    xlogo &
    xcalc &
    xterm &
    xclock &
    xmessage "Hello, world!" &
    xedit &
    The console you see in the middle is the one I used to shell into the BB.
    The 3 other windows are the logo, calc and terminal I executed on the BB that display on my PC.
    I've added comments on the GCC toolchain that has the best compatibility with the current latest BB Debian image.
    I ran into issues with my cross-compiler being a newer version than the current support on the BB Debian side.
    And at the same time, I wanted to stay as close to that image as possible, without the need to install any package on the BB side to make this work.
    Adding the 4.9.3 toolchain does the trick. And it runs perfectly together with the 5.3.1 - no conflicts
    (most challenging is doing it off the cuff in a different language. Having to think about what I'll say, speak a foreign language, explain technical things, without prep, is causing the most hick-ups during filming.
    I do this on purpose. I started making videos to improve my rhetoric skills for English meetings at work. I do it off the cuff to train my brain in freewheeling in a foreign tongue. It helps)
    Cinepak-codex
    iPad and CAMStudio snippets edited in Windows Movie Maker
    All easy tools. I also try to edit as little as I can.
    I film in the right order. (without script, as you probably can spot image )
    In Movie Maker, I cut begins and ends, cut out goof-ups, and speed up long waiting scenes (unzip, install).
    Then I generate mp4 in highest quality, and upload to YouTube.
    For this one, I started filming at 17:30. Video was edited, rendered and ready for upload at 19:30.
    This included making diner and eating...
