Legacy Personal Blogs Molex Antenna Adventures starring a RPi4
  • Author Author: wolfgangfriedrich
  • Date Created: 18 Nov 2020 2:41 AM Date Created
  • Views 5284 views
  • Likes 11 likes
  • Comments 6 comments
  • wifi
  • molex
  • molex_webinar
  • raspberrypi4
  • umc
  • antenna
wolfgangfriedrich
wolfgangfriedrich
18 Nov 2020
Some time ago, I received a Molex Antenna Kit consisting of a boatload of different antenna types. A big thanks to E14, Avnet and Molex.
These are the contents:
{gallery}Molex Antenna Kit
Antenna Kit: Molex Sample Kit
Antenna Kit: Cellular Antennas
Antenna Kit: Combo Antennas
Antenna Kit: GNSS Antennas
Antenna Kit: ISM Antennas
Antenna Kit: NFC Antennas
Antenna Kit: UWB Antennas
Antenna Kit: BT/WiFi Antennas
Antenna Kit: Selection of WiFi Antennas
As a leftover from a previous roadtest, I am also the proud owner of a PaspberryPi4 B. This mighty little computer did have bad WiFI performance in the basement, with the router being one floor up and across the house.
= imageimage
A close look at the board shows a very interesting layout for the PCB antenna. I don't even want to start thinking about, what is going on there in the RF domain.
The part that interested me most, was the empty footprint at the feed trace and the single contact, suggesting a mounting option for an UMC connector. The antenna Kit did contain a nice selection of dual band 2.4/5 GHz WiFi/Bluetooth antennas with UMC connections as well. One Digikey order later, a fitting part ended up on my desk. In the spirit of the giveaway, it is a Molex UMC receptable 50 Ohm SMD, part number 073412-0110.
A banana for scale would not work very well, so I used my EEVblog measuring stick.
The next steps are: cut trace, add wire bridge, scrape scrape scrape, solder connector in place, plug in antenna, done.
One of the camera connector slots in the housing is a perfect feed-through to get the antenna out. And there is 'plenty' of room to stick it somewhere to secure it.
A quick test, did reveal an improvement in WiFi signal strength.
= image.image
I am sure, there is some programs around to give more detailed WiFi signal strength information, but I am happy as it is. So no 'apt get ..........' session tonight, that would take longer than the hardware upgrade.
The End.
PS: I probably should scratch the FCC/CE mark off the board now...
  • wolfgangfriedrich
    wolfgangfriedrich over 5 years ago in reply to wolfgangfriedrich +3
    jkutzsch : I have some more results: as expected, unplugging the new antenna really kills the Wifi range. It detects the network up to 2 meters away from the router in line of sight or through a thin North…
  • colporteur
    colporteur over 5 years ago +3
    I sit here on Friday night with two Coors Light beers in my gullet and think WOW! I doff my hat for your initiative. I have no fortitude for putting a Pi at risk by hacking to the level you have ventured…
  • wolfgangfriedrich
    wolfgangfriedrich over 5 years ago +2
    It looks like the RPi Foundation went with my idea for their compute module: Must be a fancy RF switch. From: https://www.raspberrypi.org/products/compute-module-4-antenna-kit/?resellerType=home
  • colporteur
    I doff my hat for your initiative. I have no fortitude for putting a Pi at risk by hacking to the level you have ventured. My first RoadTest application New Year's Grab Bag RoadTest was an appeal to sacrifice a RoadTest review Pi first version generation to test an interface. I feared for the life of my Pi3B+ during testing but was willing to let go a Pi first generation.
    I received a similar antenna kit you received but I didn't get the enlightenment of possibilities you got. Great work WF, great work!
  • wolfgangfriedrich
    wolfgangfriedrich over 5 years ago in reply to colporteur
    Thanks for the kudos, much appreciated.
    I just could not pass that opportunity with the branch off and connector pad. If I can see it, I can solder it.
    - W.
  • wolfgangfriedrich
    - W.
