Legacy Personal Blogs My First Ever Crimping Experience
  • Author Author: dubbie
  • Date Created: 20 Nov 2020 2:54 PM Date Created
  • Views 5923 views
  • Likes 10 likes
  • Comments 34 comments
  • spade connections
  • crimping
dubbie
dubbie
20 Nov 2020
For my Sand Based Cat Detector (Cat Detector Using Sand #2 : The Implementation ) I used a lead acid battery with spade connections. I have never properly used spade connections before (I usually use crocodile clips or solder directly) so I thought this would be a good time to start as I am working my way towards an outdoor mobile robot and robust and reliable connections are essential. Not really knowing much about making spade or crimping connections I decide that the best approach would be to buy some and just try it out. I have wanted to crimp for some time so rather than find out about it I just blundered in and bought something. I do not expect to do much crimping in the future so just looked online and bought the cheapest set I could find that seemed to do what I wanted.
I used deep learning to update my natural neural networks in my head, basically I just stuck some wire inside the crimpets (or connectors) and tried to make good connections with the wire using the crimping tool. Initially there was little success as the tool I obtained did not come with any instructions what-so-ever. The crimpets would not stay on the wire while I attempted to use the crimping tool and several crimpets were harmed in this process.
It took me several attempts to work out that the tool I had purchased did not do any folding of the little tabs on the crimpets. Once I had worked this out and folded over the ;little tabs using some pin nosed pliers I was able to make some good crimped connections. I'm not sure if it uses cold-welding or just mechanical interference to make a good physical and electrical connection, but they seem to work, so all is good.
Dubbie
    shabaz over 5 years ago in reply to ajcc +8
    Hi Adrian, Probably everyone has their own recommendations, I've been quite impressed with the Multicomp HT-xxx range, I have several of them, they are about $25 ballpark. The HT-230 crimp tool HT-230…
    shabaz over 5 years ago +7
    Hi Dubbie, I do the same as Doug, i.e. add some solder (after crimping) if the specific crimp tool isn't suitable. However, I think maybe your tool might do both the bare wire crimping and the insulation…
    dougw over 5 years ago +5
    There is a lot of science behind good crimp connections. I suspect they rely on the wire bring more springy than the crimp terminal, so after a crimp there is always force on the joint Whenever I don't…
  • Andrew J
    Andrew J over 5 years ago
    I can't get over how expensive the crimping tools are!  I've tried a cheaper Multicomp HT which seems to work well for a variety of pin connectors and even a Faston connector.  I also have a fairly cheap knipex ferrule crimper which again works well.  I've noticed a very expensive crimper in a cabinet in the museum which I'd borrow if I needed to make specific ring connectors if the Multicomp couldn't do it.  It seems like these things could become collectors' items like old relay-maintenance tools!
  • colporteur
    colporteur over 5 years ago in reply to Andrew J
    After you have used a "good" crimper, bad crimp tools only conjure frustration and memories of a more joyous crimp.
  • Andrew J
    Andrew J over 5 years ago in reply to colporteur
    I've not tried many tools for comparison but I'm inclined to agree that it's likely to be the case!  The Multicomp crimper and Knipex crimper seem to produce good crimps based on my limited experience.  These are both less than £30 which seems like a bargain compared to the £250 RS-Pro crimper in the museum cabinet which can do one thing.  I've used it to crimp ring terminals onto wires for the Bombe and its no easier to use than the Multicomp one.  I mean, really, £250...@£$^!!
  • Andrew J
