Legacy Personal Blogs Rotary Encoders - Part 5: Capturing Input on an FPGA
  • Date Created: 15 Jul 2015 10:08 AM Date Created
  • Views 4099 views
  • Likes 10 likes
  • rotary_switch
  • spartan_6
  • rotary_encoder
  • papilio_pro
  • papilio
  • xilinx
  • fpga
15 Jul 2015
I've removed the rotary encoder from the scroll button of a defect mouse. Let's see how we can use that in a microcontroller design.
In post 1, I wired up the electronics.
In part 2, I'm capturing the encoder's info on a Cypress PSoC4.
In the third blog, I've used an Arduino.
In number 4, I'm capturing the encoder's info with the eQEP module of a TI Hercules microcontroller.
This time, I'm testing it on on a Xilinx Spartan 6 FPGA.
The Code
Disclaimer: I haven't found consensus on how to call the logic for a FPGA.
I started from a project made  by Thomas Flummer on his hackmeister blog in 2010.
He started with a FPGA servo controller that was controlled with two buttons for left and right movement.
Later he added a quadrature encoder module to control the servo position.
And that's the project that I picked up here.
https://www.hackmeister.dk/2010/07/controlling-an-rc-servo-with-an-fpga/
https://www.hackmeister.dk/2010/07/using-a-quadrature-encoder-as-input-to-fpga/
I've adapted the code using info from the following blog post:
https://groups.google.com/d/msg/comp.lang.vhdl/nD5V5v_kfLw/at8iEDFsxYcJ
It uses a deprecated math library. I switched all the locations where STD_LOGIC_VECTOR is used in calculations to UNSIGNED.
Locations where the STD_LOGIC_VECTOR is used to contain bit values (e.g. QuadA_Delayed), I have kept as is.
(I'd like a guru to have a look at what I did with PulseCount in ServoDriver.vhd)
I've also replaced occurrences of
if Clk='1' and Clk'event then
by
if rising_edge(Clk) then
The code is using direct instantiation of entities, in stead of the architecture -> component -> entity -> instance approach.
Because of that, I had to add the "work." qualifier when instantiating modules. I may change that later.
johnbeetem advised me to ask michaelkellett for a VHDL review.
Go ahead Michael.
Disclaimer 2: The project doesn't deliver correct Servo signals. The PWM frequency isn't 50 Hz, and the pulse width isn't conform the servo PWM specs.
It doesn't matter. The only thing that I want to show here is that I can increase and decrease the duty cycle of the FPGA output with a rotary encoder.
The design has 3 modules:
  • The ServoDriver: a module that generates a PWM signal with a given duty cycle based upon position info that we pass to it.
  • The QuadratureDecoder: this module picks up movement of the rotary encoder and translates that into  a position.
  • The ServoUpDown: this top module glues the two other modules together. It connects the Encoder position with the Servo position.
edit after comments below: I've replaced all tabs in the source by spaces. That resolves the indentation differences between IDE and this blog.
QuadratureDecoder.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity QuadratureDecoder is
    Port ( QuadA : in  STD_LOGIC;
           QuadB : in  STD_LOGIC;
           Clk : in  STD_LOGIC;
           Position : out  unsigned (7 downto 0));
end QuadratureDecoder;
architecture Behavioral of QuadratureDecoder is
signal QuadA_Delayed: std_logic_vector(2 downto 0) := "000";
signal QuadB_Delayed: std_logic_vector(2 downto 0) := "000";
signal Count_Enable: STD_LOGIC;
signal Count_Direction: STD_LOGIC;
signal Count: unsigned(7 downto 0) := "00000000";
begin
process (Clk)
begin
   -- if Clk='1' and Clk'event then
      QuadA_Delayed <= (QuadA_Delayed(1), QuadA_Delayed(0), QuadA);
      QuadB_Delayed <= (QuadB_Delayed(1), QuadB_Delayed(0), QuadB);
      if Count_Enable='1' then
         if Count_Direction='1' then
            Count <= Count + 1;
            Position <= Count;
         else
            Count <= Count - 1;
            Position <= Count;
         end if;
      end if;
   end if;
end process;
Count_Enable <= QuadA_Delayed(1) xor QuadA_Delayed(2) xor QuadB_Delayed(1)
            xor QuadB_Delayed(2);
Count_Direction <= QuadA_Delayed(1) xor QuadB_Delayed(2);
end Behavioral;
ServoDriver.vhd
-- Company:
-- Engineer:
-- Create Date:    16:55:40 07/14/2015
-- Design Name:
-- Module Name:    ServoDriver - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
entity ServoDriver is
    Port ( Clk : in  STD_LOGIC;
           Position : in unsigned (7 downto 0);
           Servo : out  STD_LOGIC);
end ServoDriver;
architecture Behavioral of ServoDriver is
constant ClockDiv: integer := 63;
signal ClockTick: std_logic := '0';
signal ClockCount: unsigned (6 downto 0) := "0000000";
signal PulseCount: unsigned (11 downto 0) := "000000000000";
begin
process (Clk)
begin
      if ClockCount = ClockDiv-2 then
         ClockTick <= '1';
      else
         ClockTick <= '0';
      end if;
      if ClockTick='1' then
         ClockCount <= "0000000";
      else
         ClockCount <= ClockCount + 1;
      end if;
   end if;
end process;
process (Clk)
begin
         PulseCount <= PulseCount + 1;
      end if;
      if PulseCount < ("0001" & Position) then
          Servo <= '1';
      else
         Servo <= '0';
      end if;
   end if;
end process;
end Behavioral;
ServoUpDown.vhd
library IEEE;
entity ServoUpDown is
end ServoUpDown;
architecture Behavioral of ServoUpDown is
signal Position : unsigned (7 downto 0);
begin
Servo1: entity work.ServoDriver port map (Clk, Position, Servo);
QuadDecoder1: entity work.QuadratureDecoder port map (QuadA, QuadB, Clk, Position);
end Behavioral;
Wiring the Hardware
Look back at my first post to check how to components are wired up.
Then connect the encoder with the Papilio Pro.
CONFIG PROHIBIT=P144;
CONFIG PROHIBIT=P69;
CONFIG PROHIBIT=P60;
NET Clk TNM_NET = Clk;
TIMESPEC TS_Clk = PERIOD Clk 31.25ns HIGH 50 %;
NET Clk            LOC="P94"  | IOSTANDARD=LVCMOS33 | PERIOD=31.25ns;             # CLK
NET Servo IOSTANDARD = LVCMOS33;
NET Servo SLEW = FAST;
NET Servo DRIVE = 8;
NET Servo LOC = P48; # A0
NET QuadA IOSTANDARD = LVCMOS33;
NET QuadA SLEW = FAST;
NET QuadA DRIVE = 8;
NET QuadA LOC = P51; # A1
NET QuadB IOSTANDARD = LVCMOS33;
NET QuadB SLEW = FAST;
NET QuadB DRIVE = 8;
NET QuadB LOC = P56; # A2
Ground to Ground, 3.3V to 3.3V,
PINA to A1, PINB to A2. Oscilloscope to A0.
Load the bitstream to the FPGA and rotate the encoder.
You'll see that the output signal has a constant frequency and that the duty cycle can be controlled by turning the encoder.
Content
Part 1: Electronics
Part 2: Capturing Input on Cypress PSoC4
Part 3: Capturing Input on an Arduino
Part 4: Capturing Input on a Texas Instruments Hercules LaunchPad with eQEP
XuLA2 FPGA - Rotary Encoder and VHDL
Real World Application: Hercules LaunchPad and GaN FETs: Control Big Power with a Flimsy Mouse Scroll Wheel
    Jan Cumps over 5 years ago +3
    I'm training Pynq and Zynq design. I've tried to port the PWM module of this post to that architecture. Instead of taking the input for PWM duty cycle from a rotary encoder, I take it from the embedded…
  • michaelkellett
    michaelkellett over 11 years ago +2
    It's nice of you to invite me to comment - I'm kind of busy right now so I'll be brief. First let me say that I appreciate the public service you do in posting this stuff so the last thing I want to do…
    Jan Cumps over 11 years ago +2
    I finally managed to get that video uploaded. www.youtube.com/watch
