Legacy Personal Blogs The Complete 8 Bit ALU
  • Author Author: timswift
  • Date Created: 13 Nov 2016 6:31 PM Date Created
  • Views 2345 views
  • Comments 7 comments
  • transistor
  • alu
  • computer
  • diy
  • cpu
timswift
timswift
13 Nov 2016
I finished the ALU (all 8 bits) and the test-board yesterday. It contains 355 transistors without the test board.
In all it took less then two days to construct and trouble-shoot (not including the small boards).
It is interesting to note that the ALU only had one short while the test board had two LED's soldered in backwards and a short.
The back side of the ALU;
The 34 pin connector is wired as below;
The six functions are not encoded so if more then one is selected at a time the functions are calculated and the the results are OR'd together
(I don't think this property has a practical use).
Here is the test-board (just light's and switches);
And finely the block diagram;
Tim
  • andycrofts
    andycrofts over 9 years ago in reply to sek4321 +1
    I, years ago worked on a Spectrum Analyzer, using the FFT algorithm. 44-bit microcode instruction word, directly operating shift registers, ALU's etc. Total memory 44-bit by 4-kilobyte Here's a piccie…
    DAB over 9 years ago
    Excellent work Tim.
    I admire your determination to build the ALU from transistors.
    You have built an amazing device and I suspect you have learned a great deal about the basic computing devices inside each MCU.
    Well done.
    Excellent work Tim.
    Well done.
  • timswift
    timswift over 9 years ago in reply to DAB
    Thanks!
    Tim
