I finished the ALU (all 8 bits) and the test-board yesterday. It contains 355 transistors without the test board.
In all it took less then two days to construct and trouble-shoot (not including the small boards).
It is interesting to note that the ALU only had one short while the test board had two LED's soldered in backwards and a short.
The back side of the ALU;
The 34 pin connector is wired as below;
The six functions are not encoded so if more then one is selected at a time the functions are calculated and the the results are OR'd together
(I don't think this property has a practical use).
Here is the test-board (just light's and switches);
And finely the block diagram;
Tim
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
timswift
in reply to DAB
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
timswift
in reply to DAB
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
