Legacy Personal Blogs Throwing mechanism
  • Author Author: akashm.m
  • Date Created: 15 Sep 2017 2:40 AM Date Created
  • Views 2481 views
  • Comments 17 comments
Throwing mechanism
akashm.m
akashm.m
15 Sep 2017
Can any explain me the throwing mechanism using bot .
It's a task given that we have to throw a shuttle inside the ring using a bot.
So please suggest me mechanism .
    Jan Cumps over 8 years ago +3
    I suggest using a catapult activated by a solenoid. Current will control the strength of the throw. The stop bar will give that extra kick
    balearicdynamics over 8 years ago in reply to akashm.m +2
    Just a schematic draft done in five minutes to represent the idea...
  • Sean_Miller
    Sean_Miller over 8 years ago +1
    My son and I made a tennis pitch machine with a very different approach than shown in those videos. I don't know what you are throwing, but if its round, this video will show you how to make one that has…
    The stop bar will give that extra kick image
  • akashm.m
    akashm.m over 8 years ago in reply to Jan Cumps
    Can you show me the detailed sketch bcoz shuttle is actually  a ball having a string to hold.
    We have to hold the shuttle using string .https://photos.app.goo.gl/Tu6V5thQBR6LYyuk1
  • akashm.m
    akashm.m over 8 years ago in reply to balearicdynamics
    So any idea, what else can be done?
    Wanting to avoid electro-pneumatic, a spring will throw while a stepper motor will charge the spring, it is sufficiently precise to charge the spring reaching difference throwing force level to reach a wide target range.
    Enrico
  • akashm.m
    Do you have any sketch or video so that I could understand better?
  • akashm.m
    Are we controlling this with microcontroller?
    I have a doubt that after releasing the spring will come to its initial position ,then how we can stretch it again at certain position?.
    Is it possible to control speed of motion.
  • akashm.m
    This is not the project this is the draft of the essential parts of the mechanism. The double gear is the trick image
    Take a look on how Ratchet-Gears mechanism works ...
