Legacy Personal Blogs Throwing mechanism
  • Author Author: akashm.m
  • Date Created: 15 Sep 2017 2:40 AM Date Created
  • Views 2473 views
  • Comments 17 comments
Throwing mechanism
akashm.m
akashm.m
15 Sep 2017
Can any explain me the throwing mechanism using bot .
It's a task given that we have to throw a shuttle inside the ring using a bot.
So please suggest me mechanism .
    Jan Cumps over 8 years ago +3
    I suggest using a catapult activated by a solenoid. Current will control the strength of the throw. The stop bar will give that extra kick
    balearicdynamics over 8 years ago in reply to akashm.m +2
    Just a schematic draft done in five minutes to represent the idea...
  • Sean_Miller
    Sean_Miller over 8 years ago +1
    My son and I made a tennis pitch machine with a very different approach than shown in those videos. I don't know what you are throwing, but if its round, this video will show you how to make one that has…
    The stop bar will give that extra kick image
  • akashm.m
    akashm.m over 8 years ago in reply to Jan Cumps
    Can you show me the detailed sketch bcoz shuttle is actually  a ball having a string to hold.
    We have to hold the shuttle using string .https://photos.app.goo.gl/Tu6V5thQBR6LYyuk1
    balearicdynamics over 8 years ago in reply to dougw
    Me too I have serious doubts that the design work. Based on the video sounds and kind of movements and the two clue pipes it seems that this mechanism has nothing to do with a solenoid. It seems a sort of home made electro-pneumatic actuator.
    Enrico
  • akashm.m
    akashm.m over 8 years ago in reply to balearicdynamics
    So any idea, what else can be done?
    Wanting to avoid electro-pneumatic, a spring will throw while a stepper motor will charge the spring, it is sufficiently precise to charge the spring reaching difference throwing force level to reach a wide target range.
    Enrico
  • akashm.m
    Do you have any sketch or video so that I could understand better?
  • akashm.m
    Are we controlling this with microcontroller?
    I have a doubt that after releasing the spring will come to its initial position ,then how we can stretch it again at certain position?.
    Is it possible to control speed of motion.
    This is not the project this is the draft of the essential parts of the mechanism. The double gear is the trick image
    Take a look on how Ratchet-Gears mechanism works ...
