Legacy Personal Blogs UltraZed-EV Software VCU Lib Test
  • Author Author: mollex
  • Date Created: 30 Aug 2019 2:57 PM Date Created
  • Views 1274 views
  • ultrazed-ev
  • h.265
  • h.264_encoder
  • h.264_decoder
  • mpsoc
  • vcu
  • xczu7ev
mollex
mollex
30 Aug 2019
Hi everyone!
If you want to create your project based on a VCU library or modify it, then perhaps my repository will be useful to you.
Getting Started
This repository contains example how to build library and app for an easy start debugging with it.
  -[vcu-ctrl-sw](https://github.com/Xilinx/vcu-ctrl-sw) - Official Xilinx repositories vcu-ctrl-sw
  -[vcu-omx-il](https://github.com/Xilinx/vcu-omx-il) - Official Xilinx repositories vcu-omx-il
Prerequisites
- Windows 10
- Xilinx SDK 2018.3
- [UltraZed-EV Starter Kit](http://zedboard.org/product/ultrazed-ev-starter-kit)
Set up workspace
- clone  https://github.com/mollex/workspace_uz7ev_vcu_20183
- open as workspace with Xilinx SDK 2018.3
- import projects
- set off Build Automatically
Menu: Project -> Build Automatically off
Import projects
right click on Project Explorer -> Import -> General -> Existings Project Into Workspace -> Browse -> Finish
Build
  Workspace consists of:
- vcu-ctrl-sw-xilinx-v2018-3 - main library for control vcu (build first)
- vcu-ctrl-lib-app - library for application  (build second)
- vcu-ctrl-encoder - encoder application
- vcu-ctrl-decoder - decoder application
- vcu-omx-il-xilinx-v2018-3 - omx library for control vcu (build first)
- vcu-omx-encoder - omx encoder application
- vcu-omx-decoder - omx decoder application
Prepare board
Images were taken by the  R. Jason Moss blog post (https://www.element14.com/community/community/designcenter/zedboardcommunity/ultrazed/ultrazed-ev/blog/2019/07/09/ultrazed-ev-io-carrier-card-vcu-design-example-v20183)
Source 1
- clone repository avnet-uzev-ports
- copy files from *avnet-uzev-ports/rdf0428-uz7ev-vcu-trd-2018-3/images/vcu_uz7ev_cc/*  to *SD/* card
Source 2
- download bins from dropbox https://www.dropbox.com/sh/5t0dag4momczk0j/AADh7vHkb0LU07Et-9y4ecYha?dl=0
- copy files from *dropbox/images/*  to *SD/* card
- load linux *root:root*
- connect to ethernet
- set correct IP Address
- prepare and connect WinSCP.exe by SFTP for copying files to target
Testing
Test vcu-ctrl-encoder
- copy vcu-ctrl-encoder/Debug/vcu-ctrl-encoder_debug.elf  to  /home
- copy /images/drop.yuv to /home
- copy /images/vcu_encode_h264.cfg to /home
- copy /images/vcu_encode_h265.cfg* to /home
$ cd /home
$ chmod +x ./vcu-ctrl-encoder_debug.elf
$  ./vcu-ctrl-encoder_debug.elf -cfg vcu_encode_h264.cfg
$  ./vcu-ctrl-encoder_debug.elf -cfg vcu_encode_h265.cfg
In folder /home will appear two files drop_vcuenc.h264 and drop_vcuenc.h265 files.
Copy both to Host and play with VLC media Player.
Test vcu-ctrl-decoder
- copy vcu-ctrl-decoder/Debug/vcu-ctrl-decoder_debug.elf  to  /home
$ cd /home
$ chmod +x ./vcu-ctrl-decoder_debug.elf
$ ./vcu-ctrl-decoder_debug.elf -avc -in drop_vcuenc.h264 -out drop_dec264.yuv
$ ./vcu-ctrl-decoder_debug.elf -hevc -in drop_vcuenc.h265 -out drop_dec265.yuv
In folder /home will appear two files drop_dec264.yuv and drop_dec265.yuv files.
Copy both to Host and play with YUV Player.
Test vcu-omx-encoder
- copy /vcu-omx-encoder/Debug/vcu-omx-encoder_debug.elf  to /home
$ cd /home
$ chmod +x ./vcu-omx-encoder_debug.elf
$ ./vcu-omx-encoder_debug.elf  drop.yuv --width 256 --height 240 --framerate 25 --avc --out drop_omxenc.h264
$ ./vcu-omx-encoder_debug.elf  drop.yuv --width 256 --height 240 --framerate 25 --hevc --out drop_omxenc.h265
In folder /home will appear two files drop_omxenc.h264 and drop_omxenc.h265 files.
Test vcu-omx-decoder
  - copy /vcu-omx-decoder/Debug/vcu-omx-decoder_debug.elf  to /home
$ cd /home
$ chmod +x ./vcu-omx-decoder_debug.elf
$ ./vcu-omx-decoder_debug.elf drop_omxenc.h264 -avc -o drop_omx264.yuv
$ ./vcu-omx-decoder_debug.elf drop_omxenc.h265 -hevc -o drop_omx265.yuv
In folder /home will appear two files drop_omx264.yuv and drop_omx265.yuv files.
Test v4l2_capture_raw
  Current hardware bitstream for UltraZed-EV does not include any capture port by that reason I have prepared virtual video source module vivid.ko. (use images from Source 2)
- copy dropbox/module/vivid.ko  to /home card
- copy v4l2_capture_raw/Debug/v4l2_capture_raw.elf  to /home
$ cd /home
$ chmod +x ./v4l2_capture_raw.elf.elf
  $ insmod vivid.ko
  $ v4l2-ctl --list-devices  `
      vivid (platform:vivid-000):
    /dev/video
    /dev/video1
    /dev/radio0
    /dev/radio1
    /dev/vbi0
    /dev/vbi1
    /dev/swradio0
$ ./v4l2_capture_raw.elf -o  -m -f -c 10
Files will appear in the folder */home*. Copy to host and open with YUV viewer.
Settings of files: YUV420 planar NV12 1280*720
Test drmdemo
  Connect monitor to DP UltraZed-EV.
  - copy *drmdemo/Debug/drmdemo_debug.elf*  to */home* card
```$ cd /home ```
  ```$ chmod +x ./drmdemo_debug.elf ```
  ```$ ./drmdemo_debug.elf ```
  wait ~10 sec, default path display device /dev/dri/card0
Test drmkmsdemo
  - copy *drmkmsdemo/Debug/drmkmsdemo_debug.elf*  to */home* card
```$ cd /home ```
  ```$ chmod +x ./drmkmsdemo_debug.elf ```
  ```$ ./drmkmsdemo_debug.elf /dev/dri/card0 ```
  • pierlum
    pierlum over 6 years ago
    Hello I compiled vcu control decoder app using xilinx sdk 2019.1 and I'm running it on ultrazed ev carrier card with petalinux 2019.2. VCU works because using I can encode or decode video using gstreamer. But if I execute vcu-ctrl-decoder_debug.elf I have this error:
    ./vcu-ctrl-decoder_debug.elf -avc -in testcut.
    Start
    Start
    Start
    Start
    Start
    Start
    Start
    VCU control software decoder sample app
    Allegro DVT2 - AVC/HEVC Decoder Reference Software v1.0.41 - Copyright (C) 2018
    Confidential material
    Resolution : 1920x1088
    FourCC : NV12
    Profile : 100
    Level : 40
    Bitdepth : 8
    Crop top    : 0
    Crop bottom : 8
    [ 5092.972347] Unknown ioctl: 0xC20C7102
    Crop right  : 0
    Display resolution : 1920x1080
    Sequence pictu[ 5092.978047] Known ioctl are:
    re : progressive
    Buffers needed : 8 of size 3342336
    [ 5092.986460] AL_MCU_CONFIG_CHANNEL:C2087102
    [ 5092.995392] AL_MCU_DESTROY_CHANNEL:00007104
    [ 5092.999568] AL_MCU_DECODE_ONE_FRM:C40C7105
    [ 5093.003663] AL_MCU_WAIT_FOR_STATUS:C2047106
    [ 5093.007840] AL_MCU_SEARCH_START_CODE:C4087108
    [ 5093.012195] GET_DMA_FD:C00C710D
    Codec error: Unknown error
    The error is "[ 5092.972347] Unknown ioctl: 0xC20C7102"
    What am i doing wrong?
    Thank you very much.
    EDIT: I solved downloading vcu control software sample app version 2019.2 from here github.com/Xilinx/vcu-ctrl-sw/tree/release-2019.2
