Legacy Personal Blogs Wireless Power Transfer Demo Kit
  • Author Author: djfraz
  • Date Created: 6 Mar 2018 1:39 PM Date Created
  • Views 1859 views
  • Comments 7 comments
djfraz
djfraz
6 Mar 2018
For one of my courses this year we have to design a demo/educational kit demonstrating an electromagnetic phenomenon, our group has chosen Wireless Power transfer.
Our current idea is to design a kit with two WPT antennas on a slider to demonstrate the effect of distance on the efficiency of the coils, and to have the coils interchangeable. The biggest problem we are currently facing is finding examples online of simple WPT systems proving numerical theory, we either find basic wound coil systems on the likes of instructables, or full thesis on designing an complex WPT system. I would like to ask if anyone knows of a relatively simple WPT paper (or website) which we could use as a starting point?
Here is a quick screenshot from Fusion 360 on Android of the initial design for the kit.image
  • djfraz
    djfraz over 8 years ago +4
    Thank you everyone for the information, sorry for the late reply to them Thankfully my group have agreed that i will do the mechanical design and write the report, as i am not the best when it comes to…
  • sleuz
    sleuz over 8 years ago +3
    Hey Duncan We have an app note up on e14 covering alignment, coupling and proximity of wireless power coils. ANP014: Wireless Energy Transmission Coils as Key Components We have a few more on WPT, which…
    genebren over 8 years ago +2
    Duncan, A quick search revealed a few interesting articles. I am not sure if you have come across these yet, but here is what I found: https://arxiv.org/pdf/1509.00940.pdf (if nothing else, the 350 references…
  • djfraz
    Thankfully my group have agreed that i will do the mechanical design and write the report, as i am not the best when it comes to electromagnetic theory, but i will pass on the information to them and hopefully post the completed project here as i want the demo kit to be an open source design. Maybe even someone in the e14 community would like to build and use it.
  • sleuz
    Hey Duncan
    We have a few more on WPT, which might also be of interest for you and are worth having a look.
    Wireless Power Charging Coil Changing Considerations
    Proprietary Wireless Power Transfer Solution for High Performance including Data Transmission
    Hope, this helps. Let me know, if there is anything else you needed.
    Regards
    Simon
    P.S.: Thanks mcb1 for the mention! image
    mcb1 over 8 years ago
    There was some experiments done during the "Beyond the Phone: design challenge.
    Depending on the WPT protocols, you may find the communication during the negotiating phase limits the distance, rather than efficiency losses.
    sleuz may be able to assist with your question.
    Cheers
    dougw over 8 years ago
    You can also explore how and why having the both coils operating at the same resonant frequency improves power transfer.
    shabaz over 8 years ago
    Hi Duncan,
    You may also want to experiment with a larger diameter, so that you need less tolerance in the physical design for accurate placement of the individual pieces.
    Also, since you may want to allow the experimenter to be able to plot the efficiency versus distance, some way of easily changing the distance, when the coils are close. An example could be somewhere known thickness shim could be placed (e.g. multiple 1mm thick plastic strips, etc).
