NexGen Flight Simuator Documents: Synchro and Resolver Handbook and Guide
  • Author Author: phoenixcomm
  • Date Created: 17 Feb 2025 12:07 AM Date Created
  • Views 2789 views
  • Comments 11 comments
  • flight simulator
  • nexgen
  • synchro
  • hardware
  • Synchro Handbook
  • Synchro Application Guide
phoenixcomm
phoenixcomm
17 Feb 2025
imageIf you work with robotics, avionics, an other fields that use angles you might just run into one or more these things. They are motor like devices that can transmit, or receive angles called Synchros in older aircraft they are used in pairs, imagea transmitter (tx) and a receiver (rx) . As you can see in Figure 1 by moving CG the CR will move exactly in step with its counter part. This figure is from Synchro Application Guide. There is lots more information in the Synchro handbook.
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to DAB
     DAB how does software slow down a pair of synchros?? maybe you mean hardware?? either way you have me intrigued.. Please tell me more!  ~~ Cris.
    DAB over 1 year ago
    Whoa, this takes me back to the early 1980's when I was controlling Syncros for a FLIR using radar information.
    They were very responsive so I had to build software to slow them down so the user had time to assess what was going on.
  • ralphjy
    ralphjy over 1 year ago in reply to beacon_dave
    I first encountered them as a systems engineer when I worked on retrofitting the A-6E with the Carrier Airborne Inertial Navigation System (CAINS).
    beacon_dave over 1 year ago in reply to ralphjy
    Late 80's here but they were used on antenna rotation gear to provide a remote readout of Az/El angles.
    Later moved to rotary encoders and digital readouts for computerised control.
  • ralphjy
    ralphjy over 1 year ago in reply to dougw
    I haven't used them since the late 70's when I left avionics.  I think I still have some size 11s buried somewhere in storage.
