Ralph Yamamoto's Blog Raspberry Pi Zero 2 W - MotionEyeOS
  • Author Author: ralphjy
  • Date Created: 22 Nov 2021 4:44 PM Date Created
  • Views 46025 views
  • Comments 13 comments
  • rpi camera v2.1
  • raspberry pi zero 2 w
  • video streaming
  • MotionEyeOS
  • motion eye
ralphjy
ralphjy
22 Nov 2021
This is my first post on the new site, a follow-up to I've Got To Get Me One Of These!
I'll have to admit that navigating the new site software and structure has been challenging, so it will be interesting if this works out...
I naively had thought that I could swap Raspbian OS SD cards between a RPi Zero W and Zero 2W - and that does work if you start with a recent version of the OS that knows what a Zero 2W is.  Of course, I was trying an SD card from an older Zero W - so that did not work.
I also wanted to try the MotionEyeOS on the Zero 2W since I've used that with the Zero W.  Unfortunately, the latest released image version is from last year - 20200606 - and that did not work.  I had hoped to see if I could get about the same performance as an RPi 3.
There's a lot of info on how to build your own update to MotionEyeOS, but I wasn't up to the challenge.  There was also the suggestion to install MotionEye (non-OS on the RaspbianOS, but luckily I found that "jawsper" had built a version of MotionEyeOS that would run on the Zero 2W: MotionEyeOS_RPi_Zero_2W.   For my inaugural blog, I'm going to try that out.
Here is the Zero 2W with the camera in the official Raspi case.  I 3D printed a clip so that I could tripod mount it.  The power to the microUSB is from a power adapter, but I think I'll use a USB power bank to make it portable.
This is the MotionEye Console with the image preview and the video settings below that.  I set the resolution to 800x600 and the framerate to 15 FPS.
And a short video streaming to a different browser window - there is a slight bit of lag.
I'll post this and hope that the video converted ok.
  • Oxize
    Oxize over 1 year ago in reply to Oxize
    Nevermind. Need to make a wpa_supplicant.conf in root.
  • Oxize
    Oxize over 1 year ago in reply to Choquero
    How to set wifi up? WIth the Raspberry PI imager (OS Settings?)? I still dont work after that. I see preapring AP interfaces: AP0, Configuring Wired Network (cant use this, because zero dont have ethernet). So how to connect wifi?
  • ralphjy
    ralphjy over 4 years ago in reply to Ipsleylodger
    From the MotionEye installation instructions: "Click on the user icon on the upper-left side of the page to switch user to administrator. Use admin with no password when asked for credentials."
  • Ipsleylodger
    Ipsleylodger over 4 years ago
    I have loaded your motioneye version for the pi zero2w and it boots OK. Using the webbrowser on my PC I can see the pi, but it wants me to log in but I don't know the username or password. Can you advise?
    Peter
  • Choquero
    Choquero over 4 years ago in reply to wpa_supplicant
    I was able to solve the problem thanks to the new version of motioneyes 20220119 from jawsper: github.com/.../20220119-dev
