Ralph Yamamoto's Blog Raspberry Pi Zero 2 W - MotionEyeOS
  • Author Author: ralphjy
  • Date Created: 22 Nov 2021 4:44 PM Date Created
  • Views 45652 views
  • Comments 13 comments
  • rpi camera v2.1
  • raspberry pi zero 2 w
  • video streaming
  • MotionEyeOS
  • motion eye
ralphjy
ralphjy
22 Nov 2021
This is my first post on the new site, a follow-up to I've Got To Get Me One Of These!
I'll have to admit that navigating the new site software and structure has been challenging, so it will be interesting if this works out...
I naively had thought that I could swap Raspbian OS SD cards between a RPi Zero W and Zero 2W - and that does work if you start with a recent version of the OS that knows what a Zero 2W is.  Of course, I was trying an SD card from an older Zero W - so that did not work.
I also wanted to try the MotionEyeOS on the Zero 2W since I've used that with the Zero W.  Unfortunately, the latest released image version is from last year - 20200606 - and that did not work.  I had hoped to see if I could get about the same performance as an RPi 3.
There's a lot of info on how to build your own update to MotionEyeOS, but I wasn't up to the challenge.  There was also the suggestion to install MotionEye (non-OS on the RaspbianOS, but luckily I found that "jawsper" had built a version of MotionEyeOS that would run on the Zero 2W: MotionEyeOS_RPi_Zero_2W.   For my inaugural blog, I'm going to try that out.
Here is the Zero 2W with the camera in the official Raspi case.  I 3D printed a clip so that I could tripod mount it.  The power to the microUSB is from a power adapter, but I think I'll use a USB power bank to make it portable.
This is the MotionEye Console with the image preview and the video settings below that.  I set the resolution to 800x600 and the framerate to 15 FPS.
And a short video streaming to a different browser window - there is a slight bit of lag.
I'll post this and hope that the video converted ok.
  • Selebele
    Selebele over 4 years ago
    Hi!
    1.) Rpi zero 2 w, with motion eye can't record?
    2.) I probe kerberos on rpi-z2-w but it's not working.
  • ralphjy
    ralphjy over 4 years ago in reply to Selebele
    I'm afraid that with the information that you provided, I can't really help you.
    MotionEye recording does work for me, but you do have to configure it in the settings.  Do both Still Images and Movies not work?
    I have never tried Kerberos and it seems that it has been discontinued, so I can't help with that.
  • Selebele
    Selebele over 4 years ago in reply to ralphjy
    https://kerberos.io This very good on pi3-4.  I can't find zero 2 w version :/
    In the MotionEye i I can't find a movie settings menu, motion detection.... I have rpi3 b+ . Original pi3  version, there is an movie option, good. (Just on pi3)
    I'm sorry, I don't speak perfect English
  • ralphjy
    I assume that you are using the link that I referenced in the post: https://github.com/jawsper/motioneyeos/releases/tag/20211113 for the image to load onto the SD card.
    Not sure what version of MotionEye that you are using on the RPi3, but the settings menu should be obvious.
    When you connect to the RPi, at the upper left there are two icons, one for settings and one for users.
    If you click on the settings icon it should open the settings menu (if you are logged in - won't open if not).  If you are not logged in you can click the users icon to login.
    If you scroll down the settings menu, you should see the settings for File Storage, Still Images, and Movies:
    If that does not work, I would try downloading the image again and rewriting the SD card.
  • ralphjy
