Ralph Yamamoto's Blog Solar Power Hat Fan
  • Author Author: ralphjy
  • Date Created: 2 Aug 2026 12:06 AM Date Created
  • Views 277 views
  • Likes 8 likes
  • Comments 13 comments
  • Solar Power Hat
  • E14 USB-C Fan
Solar Power Hat Fan
ralphjy
ralphjy
2 Aug 2026
This weekend I thought I would combine a couple of unused items into something useful for summer dog walks.
I received an EcoFlow Power Hat this past Christmas, but haven't come up with a use for it until now.  The hat has eight Perc Monocrystalline Silicon solar panels mounted in a wide brim.  It has a voltage regulator and USB-A/USB-C ports that have a max output of 5V @ 2.4A.  It's advertised for charging cellphones and battery banks when you are off-grid.  I also have a bit of E14 swag - a USB-C fan that I thought I would attach to the hat to provide some cooling when I'm out with the dogs.  The fan draws about 350mA, so it shouldn't be a problem even with a partly cloudy day.
Here are some pics:
EcoFlow Power Hat
Close-up of a panel
Voltage regulator and Connector module
E14 USB-C Fan
I bought a short USB-C extender cable from Amazon and printed a brim mounted bracket for the fan.
Bracket with USB-C socket
Fan mounted to the brim
And finally a short demo video (I was too lazy to find my selfie stick, so this is not a great selfie because my arm is too short).
I'm sure my neighbors will have a good time with this and I need to be careful how I turn my head...  Not sure what the dogs will think Laughing.
  • Gough Lui
    Gough Lui 2 months ago
    When I was in school, these ones were popular:
    https://www.reddit.com/r/pics/comments/4vbjc6/maybe_you_can_even_remember_these_from_the_90s/
    But with up to ~12W available, you can probably push quite a bit more air ...
    - Gough
    beacon_dave 2 months ago in reply to Gough Lui
    You youngsters with all your fancy tech... Slight smile
    About 20 years prior, if you wanted to maintain your street cred, you had to make do with one of these things:
  • stanto
    stanto 2 months ago in reply to beacon_dave
    My fingers hurt looking at this nostalgia, it was lethal with a fully charged battery.
    beacon_dave 2 months ago in reply to stanto
    I recall the position of the switch not being the best - the knuckle of the thumb could get hit by the blade tip spinning up.
  • Gough Lui
    Gough Lui 2 months ago in reply to beacon_dave
    I certainly had one of these. They actually made batteries run quite hot - especially for the ones where the motor was directly connected to the battery as likely the commutator shorts for a brief period every half-turn on bad quality DC motors. I think some of them had some suppression capacitors to improve the situation.
    - Gough
  • Gough Lui
    - Gough
