Feedback and Support
F&S Forum Creation of RoadTest Review when RoadTest is re-opened for enrolment
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Mon, 30 Mar 2026 03:26:49 GMT ETag: "0x8DE62FB5D5EDB64" Set-Cookie: .te.csrf=x5q91Vnp8CafJlsyS48PcmQBq3u9dRe3llROoamf5jo; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_NfAg004dxJNCZVogNA95sOPNcn9K2ooqO4Uw5awaqGsREzNg9HeBLx5pjEZCF35AGFldMJYBdhTXGcNVsgu4o3%2fd6QEjpB%2fTuXKRq7RJVVhdY%2bUxGm3xR8rhW3dyYW5cTHDvG2R8se02awr8mVAWFmfW8b7Xt4OWofN%2b1MPeILWet%2bnNWZDNnYpNfj5lmGPN9kFbDsvfN9SkGpCZ372qQL58C2un4ibGHR6bbnJIhBijm6nO0HdZiBPv6SG%2bWqvhlNAFE%2fk08DdFXhGzKG1VHw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=32 Server-Timing: origin; dur=49 Server-Timing: ak_p; desc="1774841209532_34864915_444467525_8050_4827_4_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 17 subscribers
  • Views 908 views
  • RoadTest
Gough Lui
Gough Lui over 2 years ago
Dear element14 Staff,
I've encountered an interesting situation, being selected as a RoadTester for the Toshiba Thermoflagger IC here: /products/roadtest/rt/roadtests/648/toshiba_thermoflagger_over-temperature_detection_ic_ref_board#pifragment-4106=9
Because this is a short RoadTest that I want to get out of the door as soon as possible, I tried to create a RoadTest Review but was thwarted. The RoadTest page button is "View entry" rather than to "Write review".
Going back to the main RoadTest page and trying to "+ New" a RoadTest Review, I get the review form but the RoadTest is not in the list that I can see.
I suspect this to be a limitation of the RoadTest app? Is there any way to easily fix this, or will I have to wait until the third RoadTester is selected before I can submit my review?
- Gough
  • cstanton
    cstanton over 2 years ago in reply to Gough Lui +2 suggested
    Hey Gough, I can see that you're currently listed as a RoadTester, I suspect you're a victim of an automated part of the system, and that the RoadTest application period has been extended. It's a guess…
  • Dudley
    Dudley over 2 years ago in reply to cstanton +1
    That's correct cstanton - it won't let you start until the application period has ended. I'm not sure it's a necessary restriction though - a confirmed roadtester should be able to start early. It…
  • rscasny
    rscasny over 2 years ago in reply to Gough Lui +1 suggested
    I closed enrollment. You should be able to post.
  • Gough Lui
    0 Gough Lui over 2 years ago
    Just thought I'd tag you, rscasny  and srutledge as you normally handle all the RoadTest enquiries.
    It is an unusual situation - should I wait until you recruit the 3rd Thermoflagger RoadTester? Or is there a way around this? (e.g. you disable enrollment, create a draft for me, then re-enable it; or there may be some setting you can change at your end?)
    Gough
  • cstanton
    0 cstanton over 2 years ago in reply to Gough Lui
    Hey Gough,
    I can see that you're currently listed as a RoadTester, I suspect you're a victim of an automated part of the system, and that the RoadTest application period has been extended. It's a guess, but I suspect you may have to wait until the enrolment period is over before you can select and choose your RoadTest Review, or maybe you'll need to be removed and re-added as a RoadTester.
    I can raise this with the dev team on Monday before the team in America wakes up, and to try to supplement that earlier I'll tag Dudley now so that he should see it first thing on Monday.
  • Gough Lui
    0 Gough Lui over 2 years ago in reply to cstanton
    Thanks for the clarification!
    Indeed, my expectation was that once I was listed as a RoadTester in the sidebar, I should be able to author a RoadTest review for that particular RoadTest regardless of the status of the RoadTest. It is very much an edge case when there is a short RoadTest being completed while the enrolment is being re-opened ... but perhaps something worth fixing to avoid it in the future.
    After all, I was hoping to upload the review this weekend (Sydney time) but alas, was not able to. Nevertheless, I also see site maintenance is coming up too ...
    - Gough
  • Dudley
    0 Dudley over 2 years ago in reply to cstanton
    It won't be quick enough for you this time around Gough Lui - but I'll pop a ticket in to get that restriction lifted.
  • rscasny
    0 rscasny over 2 years ago in reply to Gough Lui
  • Gough Lui
    0 Gough Lui over 2 years ago in reply to rscasny
    Thanks. I'll give it a try shortly, but it is morning here in Sydney and I'm preparing for work, so I don't know if it will be posted before I leave the house ...
    - Gough
  • Gough Lui
    Thanks rscasny .
    Review is now live.
    - Gough
  • cstanton
    0 cstanton over 2 years ago in reply to Dudley
    I can confirm this ticket is now raised with the dev' team.
  • cstanton
