Documents 2022 Holiday Wishlist
  • Author Author: dychen
  • Date Created: 15 Nov 2022 8:50 PM Date Created
  • Last Updated Last Updated: 30 Nov 2022 5:21 PM
  • Views 112105 views
  • Likes 17 likes
  • Comments 22 comments
The Holiday Season is here once again! Once again, we've put together a Wishlist of products that might make good gifts for engineers or makers.
This year, we've broken them down into separate lists, with a handful of items in each. However, the lists overlap. For example, a soldering iron appears in the Maker's Wishlist, but an EE Student needs one as well. Likewise, makers (and home automation, robotics, and Pi/Arduino users) would probably love to get some of the Pi/Arduino kits that appear in the EE Student's Wishlist. The only solution is to read them all!
Happy Holidays from all of us at Element14!
design challenge profile
EE Student | Makers Holiday Wishlist | PCB Prototyping | 3D Printing | Raspberry Pi | Arduino | Robotics | Home Automation
What To Buy an Electrical Engineering Student for the Holidays
For the EE students this year, we're focusing on Single Board Computers, like the Raspberry Pi and Arduino. These starter kits come with all the necessary parts to learn how to design with SBCs. For more SBC information, check out our Arduino and Raspberry Pi wishlists below.
Of course, EE Students also need tools and test equipment. For those, scroll down to our Makers and PCB Prototyping Wishlists.
GrovePi Starter Kit for Raspberry Pi
Buy Now
Components And Sensors Kit For Raspberry Pi
Buy Now
Pi-Top Modular Development Laptop Kit for Raspberry Pi
Buy Now
Grove Starter Kit for Arduino
Buy Now
Arduino Student Kit
Buy Now
For more Raspberry Pi and Arduino gift ideas, check out the Pi Wishlist and Arduino Wishlist!
Micro:bit Single Board Computer
Buy Now
Back to Top
Handheld AC/DC Digital Multimeter
Buy Now
Digital Oscilloscope
Buy Now
Soldering Iron
Buy Now
Desoldering Iron/Vacuum
Buy Now
Wire Strippers
Buy Now
Needle-nose Pliers
Buy Now
Six Piece Stainless Steel Tweezer Set
Buy Now
Helping Hands with Magnifying Glass
Buy Now
Calipers
Buy Now
Getting Started with PCB Prototyping
Back to Top
Solderless Breadboard
Buy Now
Jumper Wire Kit for Breadboards
Buy Now
Bench Power Supply
Buy Now
Resistor Kit
Buy Now
Capacitor Kit
Buy Now
3D Printing Holiday Wishlist
Back to Top
Creality CR-10 MAX
Buy Now
Ultimaker S3
Buy Now
Nozzle Pack
The nozzles in many 3D printers are interchangeable, letting you customize them. Just make sure they're compatible! This set is for Ultimaker 3D printers.
Buy Now
Gluestick
During printing, the print should be securely fixed to the build plate. Glue works well for this (and is less messy than hairspray).
Buy Now
3D Printer Filament
Buy Now
Edge Trimming Tool
Buy Now
Getting Started with Raspberry Pi
Back to Top
A Raspberry Pi is a low cost and versatile SBC, with a variety of accessories allowing you to design pretty much anything! If you're just starting out with Pi, check out some of the development kits listed in the EE Students wishlist.
Raspberry Pi
Buy Now
Raspberry Pi 4 Model B Official PSU
Buy Now
Pi Pico Starter kit
Buy Now
Roving Robot Kit For Raspberry Pi
Buy Now
Raspberry Pi High Quality Camera
Buy Now
Wide Angle Lens for High Quality Camera
Buy Now
Telephoto Lens for High Quality Camera
Buy Now
Budget Kit, Raspberry Pi
Buy Now
Pi Education Parts Kit. Components And Sensors Kit For Raspberry Pi
Buy Now
Automation HAT for Raspberry Pi
Buy Now
Getting Started with Arduino
Back to Top
Arduino is a versatile and popular controller. Just like the Raspberry Pi, there are a wide variety of accessories available. For more Arduino development kit, check out our EE Students' wishlist above.
Arduino Uno R3
Buy Now
Starter Kit, Arduino UNO, Projects Book, Breadboard, Components Kit (English)
Buy Now
Other languages available here.
Arduino Sensor Kit
Buy Now
Robotic Arm DIY Kit, Arduino Controlled
Buy Now
Getting Started with Robotics
Back to Top
There are several different types of robots: robot arms, roving robots on wheels, underwater robots, unmanned drones, you name it! The parts in this wishlist are common to many types of robots. There should also be something that controls the robot, so hop on up to our Arduino and Raspberry Pi wishlists for kits that help build the robot's brains.
Motor/Stepper/Servo Shield for Arduino
Buy Now
Stepper Motor
Buy Now
PWM/Servo HAT for Raspberry Pi
Buy Now
Push/Pull Solenoid
Buy Now
Robot Arm Kit
Buy Now
Joystick (Hall Effect Switch)
Buy Now
3-Axis Accelerometer for Arduino
Buy Now
Pressure Sensor Module for Arduino
Buy Now
Time of Flight Distance Sensor, Arduino & Raspberry Pi
Buy Now
Getting Started with Home Automation
Back to Top
The future is here, you just have to build it! Home automation encompasses a lot of things, including climate control, automated gardening, security, lighting and more. SBCs work perfectly to control everything, so check out our Raspberry Pi and Arduino wishlists above for development kits and accessories.
AmbiMate MS4 Sensor Development Kit (CO2, Humidity, Light, Motion, Temperature, VOC)
Buy Now
Camera Module with Wide Angle Lens for Raspberry Pi
Buy Now
Motion Sensor
Buy Now
Waterproof Soil Moisture Sensor
Buy Now
Door Contact Sensor/Alarm Switch
Buy Now
Relay Module for Arduino and Raspberry Pi
Buy Now
Relay Shield for Arduino MKR
Buy Now
  • stem
  • engineer
  • home automation
  • student
  • robotics
  • holiday
  • makers
  • raspberry pi
  • gifts
  • electronics
  • wishlist
  • robogary
    robogary over 3 years ago in reply to misaz +3
    I keep a post it note on my workbench with a running wishlist. The list never gets close to zero :-)
  • misaz
    misaz over 3 years ago +2
    The item mentioned as "Servo Motor" (manufacturer code 412, farnell code 2816374) is not servo motor. It is push/pull solenoid. It is the thing which I used in my project Duratool Cabinet Storage Box Upgrade…
    dougw over 3 years ago +2
    That is a great list of e goodies, maybe missing side cutters. The 2 modules I wish I had are Pi Zero 2W and Pi Pico W, so they would be good for a student as well.
  • me_Cris
    me_Cris over 3 years ago
    I recently passed the student stage, now I can call myself a maker, hobbyist, I work with electronic circuits, boards. I have some tools for electronics, hand tools, soldering iron, multimeter and so on, but in this stage of maker I am attracted more and more by big tools. A fixed drilling machine, for example, with which to make drill holes in PCBs without damaging them. If I end up getting something in the near future, it will be the Proxxon TBM220. I think this would be at the top of my wishlist.
    https://ro.farnell.com/proxxon/tbm-220/bench-drill-euro-plug-240v-85w/dp/1075578?ost=proxxon+tbm220
  • robogary
    robogary over 3 years ago in reply to me_Cris
    Thats the spirit. Go BIG or go home :-)
  • robogary
