Documents Holiday Gift List Giveaway - Circuit Assembly Tools for all!
  • Author Author: kellyhensen
  • Date Created: 14 Nov 2019 2:04 PM Date Created
  • Last Updated Last Updated: 10 May 2023 9:48 AM
  • Views 11203 views
  • Likes 17 likes
  • Comments 245 comments
Tool Giveaway for Folks Getting Started in Electronics
element14 Presents  |  Engineers and Makers Wish List |  Workbench Wednesdays
James has entire kit of must-have tools to get circuits built.  These products are all great gift ideas for the engineer (or electronic hobbist) who's just getting started since it includes the things you need to start building circuits; from a breadboard and jumper wires to a nifty assembly turntable.  It's also a great kit for updating the tools on a veteran EE's workbench.  The pliers included are the best you can get from German manufacturer Knipex.  You'll get a set of 11 different precision pliers, nippers and cutters that feel great in the hand and are lighter and thinner than what they're currently using (unless they already own Knipex).
See James' more detailed overview of the Knipex pliers in this giveaway.
THREE chance to win! Three kits of all the parts listed below will be awarded to the element14 member that tells us (in the comments below) the WORST tool to use for an electronics-related task.  This could be based on your personal experience or something that "happened to a friend."  Pictures of disastrous results will give your submission a boost.
  • Contest Opens: 18-November-2019
  • Contest Closes: 30-December-2019
  • Winners Announced: 11-January-2020
See full Terms & Conditions
What we're giving away. . .
Product Name Manufacturer Quantity Buy KitBuy Kit
MCMWire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 Piece MCM 1 Buy NowBuy Now
MCMWire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy NowBuy Now
DURATOOLTurntable, Technician Table, Rotating Duratool 1 Buy NowBuy Now
MULTICOMPAnti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator Clip Multicomp 1 Buy NowBuy Now
KNIPEX Precision Electronics Gripping Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic Pliers Knipex 1 Buy NowBuy Now
KNIPEX Electronic End Cutting Nippers Knipex 1 Buy NowBuy Now
KNIPEX Electronics Diagonal Cutters Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL Knipex 1 Buy NowBuy Now
KNIPEX Electronic Super Knips XL, ESD handles Knipex 1 Buy NowBuy Now
KNIPEX Precision Electronics Diagonal Cutters with lead catcher Knipex 1 Buy NowBuy Now
Additional Parts:
An element14 Breadboard 1
Winners! We need your details!
Else the prizes may go to someone else...
Congratulations to  mahmood.hassan  ,  neuromodulator   and  wa0zog  ! Once  cstanton  has your details or you've notified them that you've updated your details on your profile we'll have the necessaries checked and hopefully the prizes sent out to you as soon as we can
image Circuit Assembly Tools Giveaway.pdf
  • holiday2019
  • circuiteassembly
    dougw over 6 years ago +11
    In Canada, engineers are issued an iron ring after they take Rudyard Kipling's engineering oath. It is to be worn on the little finger of the dominant hand. Mine is actually made of stainless steel: These…
    genebren over 6 years ago +10
    Sometimes it is not so much the 'WORST tool for the job' but more a case of using the right tool in the wrong way. Early in my electronics career, in fact before I even had a career, while I was a student…
  • the-dubster
    the-dubster over 6 years ago +10
    I once inadvertently used my arm as a voltmeter . . . . . . . Back in 1986 I was undergoing training at RAF Cosford - Radar Technicians course, we were fault finding on the Decca Doppler system and part…
  • Attila Tőkés
    Attila Tőkés over 6 years ago
    Although they are meant to be used with electronics, these solder pumps never really works:
    I always end with up pealed off copper traces and molten plastic when trying to remove pin from a PCB:
    Or maybe, I'm using this tool wrongly...image
    • Vote Up +5 Vote Down
  • mahmood.hassan
    mahmood.hassan over 6 years ago in reply to Attila Tőkés
    And also avoid placing it exactly perpendicular to the PCB when de-soldering. Always place it slight angle and then you can save traces.
    Another suggestion is use higher wattage soldering iron (So you can melt it quickly and also avoid over heating the entire PCB) then add some solder on that pad. After melting the soldering first remove the component if its possible then clean up the pad.
    Yesterday I de-soldered these two modules with similar connectors and using only 12W image soldering Iron.
    • Vote Up +6 Vote Down
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to mahmood.hassan
    mahmood.hassan Please don't give out bad advice preferred angle is about 45 -60 degrees. Normally solder melts between 90 to 450 °C (190 to 840 °F) depending on the % of lead and tin. One of the most common is SN60 (Sn60Pb40) melts between  183 to 190 °C (361 to 374 °F)  And don't ever touch the solder to the iron when soldering. I have a series of blogs called Soldering School: it what to do, not to do, and the links to the NASA specifications as well as Student Workbook for Hand Soldering with photos. When you use an iron too little wattage (temp range) you end up overheating the parts as you must keep the iron in place way too long and you might damage components. Conversely, with too-much, you stand the chance of burning the PCB, lifting traces etc.
    This is a link to the Alloy Temperature Chart
  • mahmood.hassan
    mahmood.hassan over 6 years ago in reply to phoenixcomm
    Thanks for sharing this information again.
    And I was not talking about soldering iron angle. I was talking about desoldering pump angle.
  • Attila Tőkés
    Attila Tőkés over 6 years ago in reply to mahmood.hassan
    Oh, I actually end up lifting traces with the soldering iron, not with the pump image. What happens is that, when I try to remove a component (ex. pins) or clean up holes to install a new component, my solder pump does not sucks up enough / all the solder. Often I need to repeat the pumping process again and again, so the PCB get overheated and the trace lifts up.
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to Attila Tőkés
    Attila Tőkés ouch, what are use using for your iron? Flame Thrower? You have to know what temperature your iron is, well anyway supposed to be.
  • Attila Tőkés
    Attila Tőkés over 6 years ago in reply to phoenixcomm
    phoenixcomm, I'm using a TS100 soldering iron at around 300-320°C. The problem comes when I'm insisting too much, like for 1+ minutes image, with iron and the pump. Then the PCB heats up very much and the PCB traces sometimes get affected this.
    I think, I should try out TCPMeta's method of using solder wick with flux. I sometimes use solder wick, but never tried it in combination with flux image.
    shabaz over 6 years ago in reply to Attila Tőkés
    Hi!
    That's easy to troubleshoot, either the power or the tip temperature is too low, or there's an issue with tip wetting and the iron contact with the solder on the pad and component lead.
    If these things are correct, then the solder should be in fully melted state within a couple of seconds, even if it is a large component lead.
    I just use the flux in solder, i.e. I'll wet the tip, and then apply the iron and then maybe add some solder (i.e. adding solder to remove it all : ), but extra flux would work too. Everything is done within seconds using these methods, so no board damage.
    If you're using a TS100 iron, an issue could be the power supply (it may not be able to supply enough power perhaps). I'm just guessing though (I have not used this iron).
  • Attila Tőkés
    Attila Tőkés over 6 years ago in reply to shabaz
    The solder gets melted as it should image. Is just the soldering pump that does not sucks up all the solder, so I keep trying to suck the remaining solder up again and again (while keeping the solder molten). This is how I end up with the PCB overheated. (Yeah, I know I should not do this way, but sometimes I'm a little bit impatient image).
  • TCPMeta
    TCPMeta over 6 years ago in reply to Attila Tőkés
    Solder Braid has flux in it already but I find by adding a bit more onto the onto it on the side you apply the heat from the Iron super charges it, it will let more solder pull through into the Braid/Wick. I figured this out in desperation when I had a weak iron trying to remove something that had Lead Free Solder.
    My Solder Station is a cheap Circuit Specialists STATION-60. I think it's a cheaper variant of the old Hakko 936 that you see floating around eBay. Some day I'll buy a real Hakko FX.
  • TCPMeta
