Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10528 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • winzurf
    winzurf over 5 years ago
    When I first started developing digital systems for nuclear research (Carbon 14 dating, flame photometry, mass spectrometry, Tritium dating etc.) around 1972 I had a logic probe, logic pulser and an analogue scope, not much to test and diagnose fairly complex systems. I designed a built a test unit which had a tracking power supply (to automatically match unit under test UUT), and also drove a variety of inputs and outputs - no uP involved, all discrete logic - from memory it had 8 digital outputs both toggle and momentary, 16 channel digital inputs, latchable to monitor and capture all IC pins (had a panel so the actual pinouts could be drawn on the unit to provide immediate identification of pin functions while monitoring). Variable frequency output with variable mark to space, single pulse output with variable period, 16 bit serial data capture to monitor serial interfaces, and a race detector to measure circuit race conditions down to nS. It also had a programmable period on/off relay to allow power supply cycling of UUT to monitor reboot reliability (some circuits failed once every few days). It fairly soon became redundant as I was allowed to purchase more sophisticated commercial units, digital scopes and logic analysers, but it got me started, and on occasion dug me out of some strange design holes. Black anodised panel with lots of red LEDs, rack mounted about 4 units high it looked pretty sexy too!
    I didn't manage to save that unit, but I do still have the prototyping platform I developed around the same time - 50 years old!image
    • Vote Up +6 Vote Down
  • Andrew J
    Andrew J over 5 years ago in reply to winzurf
    Colour me impressed!  There’s something about building your own test tools that is satisfying.  Mine were all in software though, the best ones back in the early days of client-server and component-based computing.  I think that’s a way load easier than what you managed to build there.
  • Andrew J
