Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10429 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • fyaocn
    fyaocn over 5 years ago
    Multimeter is widely used entry level test/measure tool. And is the hot topic in comments. While, in my opinion, the voltage tester is the first test tools for most electronic or electrical engineer. I have lost my first votage test long ago. It is one flat head screwdriver as well, is broken one day and no longer functional.
    Here is what the voltage tester looks like.
    The voltage shall be used safely according to this picture. The tip head touch the electrified object and the other end shall be touched by tip of one finger. The maximum safety voltage is 500V, and is not accurate below 60V.
    The priciple is simple, one Mega ohms resistor and one small neon nixie tube are key components. The resistor restrict the leakage current to several mA , which is enough to drive the nixie tube when electricity cirtuit is closed. The nixie tube acts as fuse as the same time, it blows off if overvoltage.
    The voltage tester is gift from my school classmate . We share same fancy probing sockets in classroom. He share his spare one with me. By when I still do not understand fully what safety means.
    It is stronly recommended that everyone shall have the voltage tester before changing lighting bulb or change wall-mounted sockets or switches.
    It is not rare that the outer metal-clad case of electrical instrument or desktop computer is energized if grounding wire is not properly connected. For some precise instrument, such electro-magnetic effect can spoil the test results.
    I have used one voltage tester to find out one desktop computer is wrongly energized before I am electro-shocked.
    Now I have new voltage testers with upgraded functions.
    Some sore of like https://www.element14.com/community/roadTests/2240/l/Multicomp-Pro-Non-Contact-Voltage-Tester.
    Here is the picture I used now, the one on the right is new with many functions.
    Here is the botton on top shall be touched while testing. This voltage is sensitive, it can detect the electromagnatic field by 220V wire on the wall. But the LCD panel can give rough voltage level it detected. Here is the demo,
    • The socket for plug is not energized. The live wire is dead not being energized, while there are inductive voltage on the GND and Earth wire.The electrical system is not so safe and clean.
    • The socked is energized. Not the live wire is energized and the voltage indicator on lcd panel reach top of 220V when top botton touched by finger. The video is not stable, since it is shot by left hand.
    This voltage tester gives quick measure to check whether the electrical wire is safe for instruments. Of course, that is definitely important in fixing lighting and wires.
    • Vote Up +6 Vote Down
  • fyaocn
