Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10557 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • Andrew J
    Andrew J over 5 years ago
    Clearly multimeters seem to be the first test tool electronic/electrical engineers acquire and I can't compete with the examples above.  Mine was an Extech EX330 meter which I bought to go with my copy of Make: Learn Electronics image
    I read the manual (booklet) that came with it forwards and backwards.  It still sits on my bench and I still use it; I have other meters now as well but I can't see myself ever disposing of this one purely out of affection.  Besides, it's small and light and one can never have enough meters.
    However, I'd have to 'fess up and say my first test instrument was one of these:
    It still sits on the side of my bench and gets used when I need to sort something out in the house - especially if I'm drilling near a switch or socket!  Being electrocuted once is enough for anyone I reckon so every house should have one.  Not very exciting mind.
    • Vote Up +5 Vote Down
    dubbie over 5 years ago in reply to Andrew J
    Andrew,
    Excuse my ignorance, but what exactly is this pen type instrument?
    Dubbie
    Andrew,
    Dubbie
  • Andrew J
    Andrew J over 5 years ago in reply to dubbie
    It’s a voltage detector/tester.  It picks up the presence of AC voltage in wires.  So if you want to drill into a wall, for example, you can wave this around the spot and it will buzz and light up if there is a live wire.  If you want to change a wall switch or socket you can wave it at the wires and make sure you have turned off the right switch in the main fuse box.
    Of course, always make sure it works before trusting it!!
