Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10449 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • tmanelf14
    tmanelf14 over 5 years ago
    My first piece of test equipment was a Sears DMM gifted to me by my father, an electrical engineer. At some point the LCD screen was compressed and screen bleed rendered it illegible. I bought a replacement circa 2015 because of my familiarity with the equipment. Originally i used the meter to troubleshoot auto and home repair.
  • redcharly
    redcharly over 5 years ago in reply to dix
    Wowwww, the black one... It's very nice!!!
  • redcharly
    redcharly over 5 years ago in reply to thareeq
    I love this multimeter, it is the cheapest way to play with cards and electronics. Every year I recommend my students to buy a multimeter like this to start taking electrical measurements.
  • three-phase
    three-phase over 5 years ago in reply to dubbie
    Dubbie, that is what happens when you have to buy expensive test gear yourself. It was well looked after and cleaned regularly. It is back in its original case now, and when I used it on site, I had it in a more protective padded case and not the one you see.
    Kind regards
  • dingleworx
    dingleworx over 5 years ago
    My first peice of test equipment, was a strobe gun. It was essential for checking ignition timing dynamically. Superceded by fully ecu controlled ignition systems, I later gave my gun to a lad who was just starting college to learn automotive repair.
  • crisdeodates
    crisdeodates over 5 years ago
    As far as I could remember, my first test/measurement device (neglecting scale, weighing tool, etc) was an analog voltmeter which I used as a student during my 9th-grade physics laboratory at school. All were analog till I started college and worked on digital equipment from then on. Nostalgia kicking in...
    dubbie over 5 years ago in reply to three-phase
    Donald,
    It looks very clean. Are you sure you used it?
    Dubbie
    Jan Cumps over 5 years ago in reply to three-phase
    There's something odd with the image you embedded. I get an "unauthorized" error.
  • three-phase
    It will probably come as no surprise that the very first instrument I purchased was an insulation tester a few months after I finished my apprenticeship. A Megger BM200 that I purchased in the early 1990s that is still in my possession today. It doesn't work anymore and I keep trying to have a go at fixing it, but get nowhere.
    I was working as a plant electrician at the time and my shift buddy had a Fluke 83 multimeter, so together he could solve problems on the control panels and I could test the motors and cables.
    Kind regards
  • dethodeth
    dethodeth over 5 years ago
    My first VOM was a cheap Radio Shack analog my step-dad gave me back in the '80s. Sadly, it stopped working after a couple years and went in the bin.
