Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9293 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • kamakazi13123
    kamakazi13123 over 5 years ago
    My current project is restoring a 286 computer, the first thing I had to do after cleaning the termite nest out of it was mod the Dallas 1287 clock/CMOS module to be powered from a common CR2032 battery by removing the casing with a Dremel to expose the battery pins then grinded the old battery connection away, with a section of double sided tape affixed a CR2032 battery holder to the top soldered wires to the holder, and then to the pins buried in the casing bringing it back to life. I got it to boot once or twice off the old hard drive but it died soon after, so I went ahead and added a floppy drive emulator and a CF card to IDE adapter, but I ran into a problem here, I could get the CF card to be recognized as a HDD and was able to partition it, format it but whenever files where added the file names would show up but the file would not be readable and therefore could not boot from the HDD. After a bit of research I realized that the fault was it the very limited BIOS so I went on a search for a better BIOS, but there was none for the system, after a bit more research I realized that in the era of the 286 all computers were just exact clones of the IBM even if a lot of the logic chips where integrated into a single chip, it carried out the exact same function of the discrete logic and was the same as far as the BIOS was concerned, so I could use a BIOS from any computer and it would work just fine, so I found a Quadtel Enhanced BIOS that had user settable perimeters for the HDD, got a Minipro and a few NMC27C256Q EPROM chips, as I wanted to leave the old ones as they were so at least if it didn't work I could fall back to them, I also dumped the old chips to archive them. I burned the new BIOS EPROMs and popped them into the machine and the system posted! I booted from an emulated floppy and tested it by preparing the HDD again from scratch and writing a few files to it and reading them back, it passed ! last thing to do was install DOS to the HDD and try to boot from it, it worked, now I can boot to DOS 6.22. Future plans are to correct the memory problem as only two of the four simms are being recognized leaving me with only 512 K both sets seem to work, I may just go around this by installing two one megabyte simms giving it twice the memory it had, but we will see, and to see if I can find a VGA card that will work and add a sound card, perhaps one of those new ones I've seen. It's still a work in progress but that's the fun isn't it, if it were easy to fix, it would have been boring. It's come a long way from the system that would just say CMOS battery is low then halt, to a system that will boot DOS and run software.
    dubbie over 5 years ago in reply to kamakazi13123
    Maddie,
    Ahhh, 286 systems, I remember them well.
    Dubbie
    Maddie,
    Dubbie
