Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9384 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • kmikemoo
    kmikemoo over 5 years ago
    My best electronics "repair" involved a mobile mammography trailer.  This particular hospital owned two and the older one worked flawlessly.  The newer one... not so much when it ran on generator.  The voltage was either too high or too low for the UPSs (two) - causing the units to trip offline and forcing the mammograph to have to be reset and recalibrated - multiple times a day.  You can imagine the havoc that this caused with the scheduling.
    The hospital forced the trailer manufacturer to replace the generator - and experienced the same issues as with the first generator.  Both generators made solid 240VAC at 60.0Hz to 60.2Hz.  This was within acceptable limits for the UPSs.
    The hospital was furious so I volunteered to help repair the relationship.
    Long to short, it was a power quality issue caused by the UPS units.  The harmonics were causing a phase shift in what should have been split-phase 240v.  Why did the old trailer work?  Incandescent lighting.  The new trailer had LED lighting.  The solution?  Two 500w halogen work lights.
    Just this past Summer, I was able to put this solution to work again on a mobile LED movie trailer.  They couldn't get the unit above 75% brightness without it freaking out.  One $20, 1500w milk house heater later and the system goes to 100% output with not even a flicker.
    • Vote Up +5 Vote Down
  • neilk
    neilk over 5 years ago in reply to kmikemoo
    Mike - that  fix on the UPS is amazing!!!!!!!!
    Neil
  • neilk
    Neil
