Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9402 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • Gough Lui
    Gough Lui over 5 years ago
    We had a small electronic sensor design that I was called in to troubleshoot at work. This unit had just returned from contract manufacturing and had a short on the board. Without a thermal imager and with some very basic test equipment, I decided to give up on using electronic test equipment and just eyeball the board. After a few minutes, I spotted the LIS2DH "square" SMD accelerometer package was oriented the wrong way around, with the Pin 1 mark facing completely opposite to where it was printed on the board. We didn't have the time to send it all the way back to China for a touch-up, so I decided to use my untrained hands to solder it back on using a tin-the-pads, add flux, blast with a heat-gun approach. Fortunately, this worked and bought the accelerometer online and the board was now free of shorts.
    But then a second problem arose - one of our digital ADC chips was spewing out garbage data at higher rates and the waveforms on the digital side looked crook. I suspected an issue with power - a colleague confirmed it was a DGND pad which hadn't been connected since someone rotated it on the schematic and that somehow "disconnected" it. Great to know the problem, but now I'm the one that has to fix it because nobody else would attempt soldering a 30AWG wire to the "stump" of land at 0.5mm pitch.
    Not only was it successful, I repeated it a few times to bring up several more units. Not a pretty fix, but having not been trained to do SMD work, I'm glad I could still get it done and help the department deliver the devices "on time" for a media appearance demonstration.
    - Gough
    • Vote Up +6 Vote Down
  • Gough Lui
    - Gough
