Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9350 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • lonnemays
    lonnemays over 5 years ago
    The challenge was converting an RV refrigerator from an ammonia vapor absorption cooling system to a freon compressor cooling system.  This required that the freon compressor be hooked to the terminals that used to provide power to the vapor absorption system boiler. The instructions that came from the supplier of the conversion system state that the warning beeper must be disabled and the users must simply ignore the flashing error codes on the fridge front panel that indicates the heater elements have failed. (It will give this error continuously because the freon compressor draws only 1/10th the power that the heater elements did.) I deemed this ham-handed approach (disabling the warning electronics) ridiculous! What was appropriately required was to re-engineer the fridge control electronics so that it accepts the much smaller power (load current) of the compressor as a valid operating level.
    My goal, therefore, was to raise the sensitivity of the AC Heater current sensing circuitry so that it would accept the 125W load of the small freon compressor in place of the 1500W boiler heater, and not have the control logic give an error/fault indication of Open Load/Sensor ("Sr OP" was the fault displayed by my particular board).
    Having no schematic for the control electronics, and having been told by the manufacturer of the control board that the schematics and circuitry are proprietary and cannot be shared, I began the task of reverse engineering the control electronics. I soon determined, by tracing out the pathways on the printed circuit board, that the heater load power was sensed via a 500:1 ratio current transformer.
    "Aha!", I thought, "All I have to do is increase the value of the 'burden resistor' on the output of the current transformer to achieve the desired increase in sensitivity. (Since the output of current transformers behave essentially like constant-current sources, their secondaries are typically loaded by a burden resistor to achieve the desired volts-per-amp output (i.e. turns-ratio x burden resistance = volts per amp). However, and much to my surprise, I discovered that the burden resistor footprint on the circuit board was not populated on the board (no part was soldered thereon)! Without a burden resistance the secondary of a current transformer will try to rise (trying to push current through an infinite impedance) until it reaches the saturation voltage of the coil! (Not the usual practice, to be sure.) I did note that current transformer's secondary was provided some loading through a diode and capacitor feeding a voltage divider (comprising, I believe, a passive integrator/filter circuit to translate the signal to an appropriate trigger level).
    Not having the option of increasing the burden resistance (since a missing resistor is the same as a resistor with infinite resistance) to achieve the increased Volt-per-amp sensitivity, I was still left with the option of altering the turns ratio on current transformer to achieve the desired sensitivity. This necessitated unsoldering the transformer from the board, taking it apart and replacing its one-turn primary with six turns of 18AWG magnet wire. This lowered the turns ratio to ~83 and increased the sensitivity, allowing me to populate the burden resistor footprint with a 5.6K burden resistor to achieve a sensitivity of ~2.5V across the burden resistor per amp of primary current.
    The control board now functions properly with the compressor as its load, and still has all the load-sensing functionality and other features intact!
  • lonnemays
