Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9400 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
    dubbie over 5 years ago
    I think my best fix, which still astonishes me that I did it, was while still being a fairly new newbie at the University where I worked, we were always being exhorted to get out into industry and get support (money, placements, grants and so on). I was at a company trying to get a grant with them from the government when we ended up discussing a problem they had. They made some sort of equipment (I cannot remember what it was now) that needed to measure something, it might have been temperatur, and the system had started to produce apparently randomly varying measurements, only one or two degrees but it was enough to worry them. I gaily volunteered to go along and see if I could fix it - and fixing things isn't my strong point!. I borrowed the only DSO in the University, worth £4000 (the equivalent now would be about £20,000), with no permission, no insurance, no special case. After a bit of questioning it turned out the fault had appeared when they had changed from a transformer based power supply to a switched mode power supply. Eventually I was able to capture a signal from the ground line on the DSO showing a 20 mV ground bounce spike caused by the new power supply. Not being an analogue electronics person I was unable to suggest a suitable filter circuit, which would obviously have cost a fair bit to implement: more components and a new PCB. Instead, taking a much simpler approach, as the system was controlled by a PIC microcontroller I suggested that they just averaged two or three successive measurements instead. Solved the problem and didn't cost any money. I didn't even charge them for my time - it just wasn't worth the effort. Sadly, I didn't get the company to apply for the government grant with me either.
    Dubbie
    • Vote Up +9 Vote Down
    Dubbie
