Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9321 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • f1r31c3r
    f1r31c3r over 5 years ago
    Where to begin, there are way to many to put here but OK here is one most recently during lockdown.
    A Samson Servo 200 power amp blowing fuses. Most would assume Mosfet failure or something along those lines however all the power amp circuit was fine, all filter capacitors were fine and so was all the rectifier and regulation circuit.
    The toroidal transformer continuity tested fine however the inrush current limiter was burnt and cracked like a BBQ coal, the surge capacitors were exploded. Replacing these items made no correction to the fuse eating goblin Amp so a trick of the trade was needed.
    I placed an incandescent bulb in series with the mains input, yes making up a temporary circuit with some 2.5mm2 flex cord and a socket and patress on a plywood board then powered up the amp this way, the fuse did not blow and the bulb lit up. This told me the Toroidal transformer although testing fine with continuity and showed no short circuits obviously had a fault.
    I then began to unwind the toroid transformer winding by winding counting each winding one by one until I got down to the primary windings. There were no shorts, no broken enamel, no scorch marks at all anywhere in the transformer however, there it was the fault for anyone to see. The large thick gauge secondary copper windings were configured with the centre tap but instead of the copper windings being a continuous copper wire the centre tap was made of two separate windings with the centre tap being twisted and soldered together, the solder joint they used during manufacture had formed a dry joint. This is what caused the high current inrush, took out the surge suppressor and the inrush resistor and was eating up fuses.
    Cleaning up this joint, then using a 40w iron and some high quality flux and high content silver solder fixed it. The pain came when one had to wind all the turns of wire back onto the toroid one turn at a time and re-wind all the mica film tape, oh the finger blisters.
    Old amp which was discontinued and the part not available for purchase now repaired and tested working perfect. Just to make things more frustrating however, the manufacturer finally got back to me with the circuit diagrams indicating all the operating voltages to the input of the Power Supply board, so I could have had a toroid made to the now obtained specs, damn it.
  • f1r31c3r
