Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9321 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • chris_randon
    chris_randon over 5 years ago
    An IDS ueye USB camera.  Was knocked so the USB port had come off and detracked the board.  It was fun tracing the circuit, replacing tracks with narrow gauge wire.  Real sence of achievement when after the second attempt the computer recognised it.  Some epoxy and screws later it was back in the system running until a replacement could be sourced.
  • randall010
    randall010 over 5 years ago
    I just NEED proper Tools ~ Have always Wanted a Solid Soldering iron . Currently going through a Miller 211 welder that will most likely need a component or 2 pulled and resoldered. Has Stopped me from other projects as well. Have a Good One Hearts
  • messanger_05
    messanger_05 over 5 years ago
    Christmas is a time to bring joy to others, unless those others are adult siblings. Then it is time to bring joy to nieces and nephews and torment to your siblings for past wrongs, perceived or real. It is in that vein that My Greatest Fix occurred and saved (or ruined) the day by bringing a megaphone back to life.
    I am the youngest of three brothers and our middle brother is the only one with children, having two sons aged 7 and 4. Of course, this means that our oldest brother and I take it upon ourselves to provide the kids with the most obnoxiously loud and annoying presents possible and this year was no different. The kids got a megaphone, complete with recording, playback, and siren functions. Upon first opening it, we found it didn't work at all! This being an electronic toy and me being an electronics engineer and the youngest, it was tossed to me with the command of “Fix it”. Knowing cheap electronics are not the most robust and once the magic smoke is gone, it's gone, I was not optimistic.
    The kids father (our middle brother) was previously an avionics technician in the Air Force and had a DMM at home since he knew their worth for general home repair and use. It was a Fluke and I was jealous. My own DMM at home is a simple one from Sears I’ve had for over a decade and never replaced because it’s never stopped working. So I grab the DMM, opened the toy megaphone and start probing with a wide eyed 7 year old staring at me.
    My nephew had recently seen a cartoon that featured a “lightning stick” and was just grasping the idea of “completing the circuit” to have electricity flow. He was also at a stage where he was in awe of his uncle, being an Engineer, who understood electricity and how “lightning sticks” work. With this in mind, I was showing him how I probed the wires on a continuity setting to see if they were broken or not connected, checked the voltage from the battery pack to the (very few) components to make sure voltage was present, and discovered the switch was not allowing the voltage through it in the On state.
    At this stage, after finding the problem I would normally turn it over to my technicians to do the actual work of replacing the faulty component. But there was no way my older brother would act as my technician and take repair instructions from me. So, I gave the simple on/off rotary switch a detailed look and saw that the metal leads were not springing back together when it went from Off to On. I grabbed my specialty pointy tool (DMM probe) and applied some pressure to the reluctant switch leads; broken On is better than broken Off for a brand new toy (though it didn’t break it after all).
    And that is how the megaphone was saved and we all got to endure multiple days of a 7 and 4 year old taking turns to scream into a megaphone, record it, and wander the house with it playing on repeat. I don’t know what happened to that toy after we left, only imagining that it mysteriously broke once again…
    While it may not have been my most challenging or most needed fix, I like to think that seeing a toy go from broken to fixed reinforced my nephew's interest in science and engineering; that makes it my most memorable fix.
  • kc8jwt
    kc8jwt over 5 years ago
    I actully have two stories of something that I fixed when I was in my electronics program in high school.
    My instructor had me look at a TV that the librarian brought in to look at. They had replaced an SCR in it, but the TV wouldn't fire up unless you shorted the case of the SCR. No one could figure out what the issue was including the instructor who had been a TV repair man before becoming a teacher. I started pouring over the schematics and started testing everything leading up to the SCR. Everything was checking out when the TV was running. So I decided I would unsolder some of the components leading to the SCR and test them out of circuit. I unsoldered one electrolytic capacitor and found it had leaked and was pushed up. Visual inspection didn't catch it because it was on the board side of the capacitor. Replaced the cap and it worked normal then.
    In the same class we had a guy bring a TV in that was just rolling and no amount of adjusting the horizontal hold would keep it still. When I opened it up, I found the PCB was cracked and that was why it wasn't adjusting. I ended up repairing the PCB by jumping the traces and the TV worked fine after that.
  • darrenlewis
    darrenlewis over 5 years ago
    I bought a gaming pc I'd saved months for off ebay, it arrived and wouldn't fire up, I'd taught myself basic electronics as a kid making kits and got into making car alarms etc for friends, I'd opened it up as I'd been told "tough, it was working when it left and sold as is"
    I was pretty devastated $800 gone.
    A good 2 days of prodding and probing and was about to give up when I thought I'd check the power supply, a poke and porod and I'd found my gremlin.
    A new PSU at $60 and I'm happy as.
    Good luck everyone.
    Merry Christmas
  • rancell
    rancell over 5 years ago
    My best disaster was soldering the connector backwards on a Raspberry Pi Scroll pHAT. Instead of soldering only the four pins I needed I solder far more before realizing. No solder pump or wick handy made for some fun desoldering and just connecting it with wires in the end :/
    dubbie over 5 years ago in reply to raff-azsphere
    A good fix.
    Dubbie
    dubbie over 5 years ago in reply to goodgnus
    A good fix.
    Dubbie
  • superhans1981
    superhans1981 over 5 years ago
    By best electronics repair was a Yamaha home theater amplifier I'd purchased off a well known auction site, upon delivery the power delivery board had snapped clean in half, managed to strip and solder all of the traces back together, used some 0.5mm single wire thread (picture hanging wire) and a lot of solder to reinforce the joins and had it functioning again, it wasn't pretty but it worked
  • Andre_Powell69
    Andre_Powell69 over 5 years ago
    I worked for the company that put the Audio Visual System in to the Northern Line Underground trains.
    As a Design person we all had to do a two week rotation into the test/fix department.
    One of the boards had defeated a REALLY Good Test Engineer, so when I rotated into the department a wicked grin broke across his face and said
    "You Design guys think so good, well fix this board then !"
    I started on the initial boards to test them and then fixed if there was an issue.
    I then turned my attention to the problem board.
    Went through the test process, could see there was an issue and then started probing with a scope.
    I couldn't see any issues either.
    At this point I needed TEA so when to get some.
    On the way back I got back to my bench and tripped over a stool.
    As I went down my eyes went past the bench level and could see there was a tiny gap between one of the Processor pins and the board itself !
    I got up and took the board to one of the ladies who was awesome at soldering (Shirley you are still a legend in my view !).
    She very quickly did the repair and I took the board back to retest it.
    Lo and Behold the board came up so I put it in the fixed.
    The Test Engineer came up to me with a smirk on his face
    "So Andre you fixed that board yet ?"
    "Yup it's over there"
    "Oh yeah we'll test it shall we" think I had told a porky.
    "Ok"
    He set up the rig and pressed the test button and the board passed.
    "F^&% it working !"
    "I know"
    "I've been working on this board for over a month !"
    So we got some more tea together and told him how I did it image.
