Arduino Projects
Arduino Projects
Blog A simple DIY Oscilloscope with Arduino Uno and Mega
  • Date Created: 26 Dec 2014 11:05 AM Date Created
  • Views 40138 views
  • Likes 20 likes
  • Comments 79 comments
  • mega
  • ardbeginner
  • tft
  • oscilloscope
  • uno
e14 Contributor
e14 Contributor
26 Dec 2014
My DIY Oscilloscope, how i got my signal image
Content :
- Description
- Screenshots
- Video
- Credits and links
Descriptions
I am experimenting with RF and IR signals in various frequencies and had some trouble with the receivers and needed to see what kind of signal i was receiving.
I cannot afford a real oscilloscope but i knew about the older Arduino oscilloscopes.
After trying many different versions of code and tutorials, I was unable to get a single one to work, and all the tutorials and guides around was 2-3 years old.
Not sure if it is the IDE or the actual hardware that has changed in such a way that it didn't work anymore.
I finally found a working oscilloscope from a Japanese website, (linked below) and a working TFT screen library,
meaning i could read the various signals received.
Clearly the limitations are 0-5v but that is fine, what i needed to know is either wave type and frequency, and this is sufficient.
It also gives me an indication of the amplitude which is just a nice bonus.
But what I'm most happy with, is the two channel feature, i often use the second channel as a reference point to be able to
differentiate the main channel on the screen.
Some screenshots..
This is the .96" OLD test, single wave test imageimage
2.4" TFT screen on the Uno,    two right images same screen on a Mega.
A youTube vidoe i made on the experience.
Credits and Links :
My compilation of the Oscilloscope and TFT library  ( what you see on the video and images ) :
https://dl.dropboxusercontent.com/u/19761809/arduino/Vaupell-Oscilloscope.zip
Original Oscilloscope link (code by : Noriaki Mitsunaga ) :
http://n.mtng.org/ele/arduino/oscillo-j.html
Original TFT display link ( TFT shield library source ) :
http://www.smokeandwires.co.nz/blog/a-2-4-tft-touchscreen-shield-for-arduino/
TFT library :
Library : https://github.com/Smoke-And-Wires/TFT-Shield-Example-Code
    e14 Contributor over 11 years ago in reply to 4ringfan +2
    True, I highly recomened if using ribbon cable, buy a roll, and add the ends yourself, much much cheaper. I usually buy them home in 10 meters at a time. But, I try to use cable as little as possible,…
  • 4ringfan
    4ringfan over 11 years ago +1
    I just received a LCD TFT shield that I had ordered for no particular reason. Now I'm going to have to play with it. Thanks for the incentive!
    e14 Contributor over 11 years ago in reply to e14 Contributor +1
    Nope just one of them. The problem was the Screen it took up all my pins on the arduino uno. You could do a messy workaround, either by soldering something onto the SD pins (since were not using them anyway…
  • dmaruska
    dmaruska over 11 years ago in reply to niq_ro
    I just down loaded it from the first link, and unzipped it with no problem.  Try a DIFFERENT zip/UNzip software....
  • niq_ro
    niq_ro over 11 years ago in reply to neilk
    I can download the file too, but if I want to unzziped send a message for a corrupted file..image
  • neilk
    neilk over 11 years ago in reply to niq_ro
    niq_ro the problem must be at your end - I just downloaded the file (again) a few minutes ago.
  • niq_ro
    niq_ro over 11 years ago in reply to niq_ro
    link https://dl.dropboxusercontent.com/u/19761809/arduino/Vaupell-Oscilloscope.zip has a broken archieve image please help me with a good one
  • niq_ro
    niq_ro over 11 years ago in reply to e14 Contributor
    fantastic .. if you can see the sketch, but link give a broken archieve image
