Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 69955 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
  • sciguy14
    sciguy14 over 15 years ago in reply to e14 Contributor
    Have you tried using an x86 version of the compiler?
  • sciguy14
    Any of them.  All arduino are essentially the same.  Only memory, clock speed, and form factor differ.
  • sciguy14
    Which board you get depends mostly on the space you have available.  You'll need to choose a balance between features and physcal size.  Using the XBee alone would be a good solutions ,since you wouldn't need an arduino on both ends that way.
  • sciguy14
    That's all possible.  The lookup table can be a simple array that you store in memory.  You would need to use something like a binary search to find your temperature (http://en.wikipedia.org/wiki/Binary_search_algorithm).  It would be easier to find a best-fit formula that relates voltage to temperature, and use that.
    You can store values to an SD card to look at later.  I have a tutorial on how to do that:http://www.youtube.com/watch?v=5v5A3j7Rrco
    I'll have a tutorial on how to use an LCD screen soon as well.
    e14 Contributor over 15 years ago in reply to sciguy14
    IF i only use te Xbee antenna hooked up to the accelerometer, is there a speacial  program for the Xbee to display the data on the computer?
    what programming language would i be using to write te software i need for tis system? (i know java, c, c++)
    2) can i use an accelerometer to measure the force applied to a surface? ( i know there are force/pressure sensors but I'm trying to use few hardware components)
  • driggs
    driggs over 15 years ago
    Jeremy, How do you access the serial number of an atmel controller from the chip?
    thanks,
    Dennis Riggs
  • sciguy14
    sciguy14 over 15 years ago in reply to driggs
    Connect to it via the ICSP programming pin, and use a program like AVR studio to read the chip info.  You could also do a dump using avrdude.
  • sciguy14
    XBees have the ability to transmit signals from a few digital I/O lines.  You would just need to feed those same lines into an arduino on the receiving end, then hook that arduino up to the computer via serial.  You can write the computer software in any programming language that can talk to a serial port.
    I can't think of a way to use an accelerometer to measure surface force.
  • driggs
    driggs over 15 years ago in reply to sciguy14
    Do you have a sample code that can do that?
    thanks,
    dennis
  • sciguy14
    You don't need any code.  You do, however, need an ICSP programmer, or a second arduino that you can configure as one (http://arduino.cc/en/Tutorial/ArduinoISP).  Once you get that hooked up to your computer, you can connect to it with AVR studio, and look at the serial number, etc. (http://www.atmel.com/microsite/avr_studio_5/default.asp?source=redirect)
